Results 11 to 20 of 21
- Feb 2008
- 76
March 26th, 2010 05:09 PM #11* rocksteadyian same lang problema natin, nissan series 3 kotse ko, kapag tumatakbo yong kotse ko then magtratraffic biglang magtaas baba yong rpm (1500) tapos namamatay ang aircon, ganon daw talaga yong computer natin pinapatay ang aircon kapag nakasense sya ng mga problema (overload). try to check with this thread baka makatulong..
http://tsikot.yehey.com/forums/showthread.php?t=68179
March 26th, 2010 06:28 PM #12
a friend had the same problem last year, something to do with the magnet thingy sa compressor. Buti nalang pwede pala i repair.
- Jun 2008
- 1,741
March 27th, 2010 01:07 PM #13
March 31st, 2010 10:00 AM #15
depende kung alin ang aayusin. kapag linis evap sakin e P1.2k. hindi nalalayo yung sa condenser., mas mahal ang compressor repair. at depende pa kung irerebuild compressor mo. i.e. palit o rings, oil, magnetic clutch etc.
yung sakin kasi nun e continuous running naman compressor ko during idling kahit malamig klima. nag ooff lang kapag running na. pero cool pa rin. pinalinis ko evaporator e ayun normal operation na.
March 31st, 2010 10:15 AM #16
bro why not pa cleaning mo muna aircon then sabay mo pa diagnose yung tungkol sa condenser. Yang ganyang klase kasi parang kulang na yung nagpapalamig sa condenser mo, might be faulty aux fan o kailangan ng isa pa dahil sa matinding init.(you mentioned kasi pag matindi lang init nagkaka ganun) Unang step kasi gagawin nila eh check yung charging system para malaman kung ok pa freon at bomba ng compressor, tapos evap naman at compressor ang ipepressure test kung may leaks. I'm sure mahuhuli ang culprit dyan at malinis pa aircon mo.
- May 2009
- 1
April 13th, 2010 01:12 PM #17try mo papalit yung filter/drier receiver. yung sa kin nissan serena, pag mainit din nawawala yung lamig. ganun ang suggestion nung suki namin car ac specialist.
- Apr 2010
- 1
April 22nd, 2010 07:57 PM #18I recently encountered the same issue (tumataas bigla yung menor pag traffic and nawawala na rin yung lamig kasabay ng pagtaas ng menor), I thought it was my fan because prior to this my fan broke down, fuse lang sira so nung pinalitan yung fuse gumana na yung fan. So back to the issue, the technician said that my condenser could be clogged and might have to be replaced. nagpa-2nd opinion ako then I mentioned the fan and condenser story. Sabi nung pangalawang tumingin, ok naman daw yung lakas ng fan ko and yung condenser daw mukhang marami lang alikabok. So he suggested that I have my condenser pressure washed pag nag-pacarwash ako, make sure lang daw na sabog na tubig wag yung patusok para hindi mabutas yung condenser ko. Presto! after ng carwash ko, ok na aircon ko at parang mas lumamig pa. So suggestion ko, if you encounter this issue, pa bombahan nyo muna yung condenser nyo pag nagpa-carwash kayo, pag hindi naging ok then tsaka nyo patingin sa aircon shops. HTH.
April 26th, 2010 11:06 AM #19
hope this link helps...
http://www.trustmymechanic.com/ac_troubleshooting.htm
April 26th, 2010 07:35 PM #20
Sakto brad.
Yung mechanico namin ng aircon nung na check nya. Mabagal lang ang RPM ng fan.
Kailangan mabilis ang ikot. At napansin nya na kapag naalog tumitigil yung fan.
AUX fan lang talaga ang sira ng ganito.
Bale 500 bili kosa AUX fan para sa nissan sentra lec yung 2 wires daw.
So bale 1200 aircon cleaning na ren at charge ng freon so bale
1700 lahat ok na ulit sa tag init. Ayos
Yes, i do think so. Since it's based on the 4th-gen delica/space gear, which in turn shares some of...
Mitsubishi Philippines
