Results 11 to 17 of 17
- Aug 2006
- 98
November 8th, 2013 09:31 PM #11By the way mga sir, ilang liters of coolant po ba normally ang nilalagay nyo after maoverhaul ang rad?
- Jun 2009
- 2
November 10th, 2013 01:24 AM #12sir you have a '92 Honda, so I assume na wala pang ECU or computer box yang car mo, carburetor type.
I suggest of removing the thermostat, with this kasi the coolant mix are always circulating and the temp is somewhat constant, unless you have other problem
for the coolant, if you've tight budget use wilkins distilled water mas mura kesa sa mga coolant sa market
- Aug 2006
- 98
November 10th, 2013 03:25 PM #13Yes sir, carb type po. Hmmmm, from the threads Ive read...removing the thermostat is big no no, right? Pag inalis yun, medyo tataas daw ang FC, aside from that kelangan irekta na ang fan so hinde na marereach ng engine ang required temp nya...and in the long run, it will create bigger problems di po ba?
- Oct 2013
- 170
November 10th, 2013 07:54 PM #14
November 11th, 2013 11:03 AM #15
- Aug 2006
- 98
Tsikot Member Rank 4
- 2,719
November 11th, 2013 03:23 PM #17when the radiator is overhauled, practically all the coolant is drained ... you will need 4-6 liters (depends on engine size) to replenish ... the coolant volume is usually stated on owner's manual
