Page 2 of 2 FirstFirst 12
Results 21 to 35 of 35
    Aug 2005
    Quote Originally Posted by fLaKeZ
    i've just checked the engine bay of our 98 civic. naka r13 na rin pala. yahooo!!!
    Do you mean r134? my brother's adventure 98 also runs with the r134 type hfc
    Quote Originally Posted by leinahtan
    hini ko natandaan e, basta nakita ko r13. hehehe. teka, iba pa ba un? i mean bawal pa rin ung ganyan?
    Dali lang naman change if ever, drain all freon and oil, change the drier and expansion valve ata, then refill with appropriate oil and freon.... I suggest you go to a shop with the right equipment to fully drain the existing freon and not yung pinapakawala lang basta basta.... I suggest you send ZEAGLE a PM or go to their Denso shop in Makati.
    Hi guys,
    I think may mas malaking confusion dyan sa LTO with regards to R134...kasi halos sa 3 LTO offices (La Loma, San Juan, Tuazon) na napuntahan ko...ang alam ng LTO basta 1998 below ang model ng sasakyan eh hindi pwedeng i-rehistro ang kotse. Ndi nila alam na ang pinag-uusapan eh yung R134 vs R12 na cooling agent ng aircon...
    Ang alam nila basta yung 1998 and below na kotse eh ndi pwdedng i-rehistro (kasi nga napa-balita sa TV na hindi pwdeng i-rehistro sa LTO ang mga car aircon na ginawa 1998 below...so it follows for them na pag ang kotse eh 1998 and below eh ndi rin pwedeng i-rehistro)
    Jan 2003
    so it shows how inteligent LTO people are
    Oct 2005
    here in the philippines, imo, kaya may ganyang patakaran e para kumita lalo ang LTO...how? 1 word: LAGAY
    sa tingin nyo?
    May 2004
    ******* sila mga taga LTO... Dapat may atleast 1 year abiso para makapagpalit yung mga hindi pa r134... So now if nagka problem aircon ko convert na....
    Kasi ako nakarehistro kahapon lang... Same procedure as before 1. emmission 2. Stencil 3. Hintay 4. Bayad 5. sticker... Im using R12 pa since bago pa compressor ko and bagong linis...
    Ang stupid nila... Ano gusto nila bumili ng 98 up lahat ng tao all of a sudden.... Pakisabi sa kanila itapon na ng mga gov't officials ang mga 97 and below na S Class, 7 Series, Range Rover at other luxury cars nila ha.
  9. #9
    parang emission test din ang mangyayari dyan, sa una lang mahigpit pag nagtagal, money-making test procedure na naman.
    Quote Originally Posted by RedHotBlood
    absolutely right.the emission testing was supposed to reduce smoke belchers out on the streets.it turned out to be a money well for certain nutheads
    Mar 2005
    guys, thanks for all your replies. I appreciate all the help.
    May 2004
    totoo yan... Had my emission test hindi man lang kinabit yung device sa tambutso ko... Result and bayad na lang... Kakilala kasi nung taga LTO... Although I bet hindi ako babagsak sa emission kasi I mentain my car Properly...
    Apr 2008
    1996 model up dito sa philippines kahit anong brand R-134a na siya, Pero my nabibili pang R-12 sa market, my mga shop R-12 ang ikinakarga para malaki ang kita, By 2010 sabi ng DTI totally di na makakapasok sa Philippines ang Refrigerant R-12, para masunod ang itinatakda ng Clean Air-Act.....mabuhay...
    Jul 2006
    Actually, R134a was mandatory in 1994 so you can see cars that have R12 for 1993 and older models, while 1995 and above usually already had R134a as standard. I have seen this myself since my wife's former 1993 Sentra had R12 while our 1995 Corolla had R134a.
    R134a is a smaller molecule so if you want to have it converted, have all seals and O-rings replaced so that the smaller molecules will not escape as easily as R12. R12 has larger molecules so with the normal seals and O-rings it won't readily escape through leaks. Also, since R134a is a less dense substance, a higher pressure is required to run the AC system in a converted vehicle (usually cars 1993 and below) so you might expect a bit more fuel consumed through this. If the R134a is standard on the vehicle then you don't have to change fuel consumption figures to compensate for it.
    Jan 2008
    i own a 97 nissan sentra lec. r12 pa rin sya.
    sabi sakin ang kailangan for conversion is flush the freon & oil, change the drier, then load up with r134 coolant.
    malaking tanong nga kung paano made-determine ng lto kung r12 or r134. ok lang siguro kung yung mga compliant lusot na. pano yung r12 na converted to r134?
How to know if your aircon is already R134?
