Results 11 to 20 of 24
- Jul 2008
- 3
July 2nd, 2008 10:37 AM #12Correct. But common sense should have dictated that distilled water is still the best way to go. Soft water may still contain small amounts of Ca and Mg and may not entirely be eliminated (hence, the term "mineral water" : meaning, it still contains minerals). I don't see the point of putting mineral water in you radiator when distilled water basically costs the same and is readilly available..gets???
- Jan 2008
- 380
July 2nd, 2008 11:45 AM #13Dun sa casa, tinanggal talaga yung radiator ng kotse ko, pero gumamit muna ng 'in-house' radiator flush bago tinanggal.
While the radiator was being reverse-flushed, yung engine pina-andar with a supply of running (tap) water through a hose.
Lahat ng cooling system hose and reservoir was flushed.
Tapos, balik na, and the 50/50 glycol/distilled water was put in, and it was good for the next five years.
Tsikot Member Rank 5
- Nov 2003
- 3,848
- Aug 2009
- 24
March 26th, 2011 04:28 AM #15
Your arguement is good only in paper. However, you won't distincly see scaling in clear plastic bottles since it won't stick to plastic due to absence of ionic charge. While metals do have a charge. Only way to verify their presence/absence is to boil the water. If there is no chalky residue at bottom of vessel after you pour out the hot water, then there's no Ca/ Mg.
Chaulky residue on containers of tap might be other impurities, since Ca/Mg do not have exclusive affinity to surface tension. And if it does, they won't be visible in bottles since they are filled to the rims.
Distillation burns off all remaining Ca/Mg
You might have a major in Chemistry but I'm a genius
- Mar 2011
- 44
May 2nd, 2011 08:33 AM #16
- Jan 2007
- 409
May 2nd, 2011 01:19 PM #17
- Sep 2010
- 70
May 2nd, 2011 03:49 PM #18
November 26th, 2017 09:54 AM #19
Mga bros, nag flush ako radiator
ok ba yun condition nung water?
Yun white debris, galing sa basin mismo.
Lagyan ko muna distilled water, pwede ko na ba lagyan long life coolant after?
Thanks
Sent from my SM-C900F using Tapatalk
November 26th, 2017 01:34 PM #20
ilang taon na yan sasakyan? looks clean and alaga naman..
VinFast VF 3
