Results 1 to 10 of 24
- 46
April 25th, 2003 01:47 AM #1Paano nga ba ito ginagawa? How do they do it in the casa or those MIDAS shops?
DIY yata ang gusto ko dahil madali lang naman yata.
- Nov 2002
- 194
April 25th, 2003 02:30 PM #2Flushing the radiator is easy, DIY lang:
1. Remove the radiator drain plug (usually nasa bottom part ng radiator) then let the water flow.
2. Remove also the water/coolant on the reserve tank as this may also contain dirt accumulated over the years.
3. Put back the drain plug and add a radiator flush like Whiz or Snap. Then fill the radiator with clean water.
4. Run the engine for about 10-15 minutes (gusto mo patakbuhin mo muna yun car mo around your village :lol.
5.Let the engine cool down then drain the water in the radiator (siguro mga 2 hours medyo malamig na yan car mo).
6. Check for leaks in the radiator hoses and check also if the radiator cap is still ok
7. Then add distilled water and coolant (minimum 50/50). Put pure coolant to the reserve tank (don't overfill, may indicator naman yun, around half of the tank ok na).
yan ang ginagawa ko every 2 years kaya 10 yrs na radiator ko ok pa rin, radiator cap and some hoses pa lang napapalitan :D HTH
- 46
April 28th, 2003 05:22 PM #3pdc2,
Thanks for the nice and clear instructions. It sure will save me some 500 bucks sa service from those big shops.
BANNED BANNED BANNED
- 3,790
April 29th, 2003 09:56 AM #4Pagbarado or suspekted barado, you can remove the whole radiator and do a back flush. Meaning entry ng water sa bottom hose hole and out sa top hose hole. Binabaligtad ang radiator that is why you need to remove it.
- Apr 2003
- 526
April 29th, 2003 12:34 PM #5pano po sinusukat yang 50/50 mixture na yan? yung PEAK pwede d ba?
meron ding binebenta sa caltex yung extended life coolant. it's a relatively small bottle good for 1 radiator na yata. ok ba yun?
- 46
April 29th, 2003 05:04 PM #6Good!!
Had my car and van done by myself this morning. Madali lang naman pala.
One of the radiator flush's instructions was to have a very slow water hose put on the radiator top while the engine's running so that you can see when the remaining coolant will drain out until it turns colorless. Dont put on a high pressure hose or else baka ma-'pasma' si kotse mo.
Also, I used mineral water (soft water) instead of distilled water - scaling lang naman yata ang concern so I guess pwede na ito.
- Nov 2002
- 194
April 29th, 2003 07:09 PM #7choy,
nabasa ko before here sa board na mineral water contains minerals that could harm your radiator...that's why the best pa rin ang distilled...ako i used SM Bonus or absolute distilled water, cheap lang naman sya.
icon, saw that PEAK coolant sa PriceSmart. Will try it nga next time :lol: Para sure ka, yun pre-mix na lang bilhin mo, no need to add water.
April 30th, 2003 05:18 PM #8
choy, using mineral water will promote scaling and rust. you should've used distilled water, the point in using this is wala siyang minerals. advice lang pare, drain mo ulit yung cooling system mo, then use distilled water asap. in a few months time, magbabara ang cooling system mo, believe me. huwag ka manghinayang kung bibili ka ulit ng coolant.
- 14
May 1st, 2003 10:46 PM #9another way of flushing is thru descaling, it also effectively cleans the engine block. but its a little bit expensive (1k++)
- 46
May 2nd, 2003 05:04 PM #10Point of argument:
Mineral water does contain minerals but it is without the scale-causing Calcium and Magnesium ions (which when combined with metals, form oxides or salts). Mineral water processed in the shops pass thru the - water 'softening' stage. Have majored in Chemistry so I believe this is how it goes.
Practical explanation - you dont see scaling in your 'mineral' water containers, do you?
Tap water used in containers do have a lot of these scale causing minerals, thus creating chalky residue on top.
Interesting thread—really important to consider the broader impact of the National ID Law beyond...
National ID Law
