Results 11 to 16 of 16
October 13th, 2010 10:37 PM #11
Nangyari na kasi sa akin yan sa dati kong Chevy cavalier broTS, bago na lahat, radiator,thermostat,cooling fan,water pump...overheat pa din..
Cylinder head gasket na pala....after mareface at palitan ang gasket, ok na siya.....
Goodluck na lang...
October 14th, 2010 10:11 AM #13
The heater cools down the coolant because coolant is what goes through your heater to heat the car.
If all the hoses are new and the radiator is not leaking and you're still losing water, it might be the cylinder head, but I'd get a compression and leakdown test to find out for sure.
- Dec 2010
- 3
December 6th, 2010 03:43 AM #15how did you fix your car??
[SIZE=4]Chevrolet optra radiator cap explode from high pressure?[/SIZE]
the temperature rises up to near to 1/2 of the temp gauge there is extreme steam pressure in the upper radiator hose, and when i touch it it's very hot and smell is coming out of it, and after some time the radiator cap neck explode i went to service center and they replaced the below list :
1. Gasket valve cover
2. Gasket Cylinder head
3. Gasket intake manfol
4. Gasket exhaust manfol
5. Hose heater inlet
6. Hose Radiator inlet upper
7. Hose map sensor VAC
8. V belt T250 11%
9. Valve inlet
10. Spark plug
11. Spray carb SF
12. Seal Camshaft FRT
13. Seal water pump
14. Seal Eng Cool thermostat
15. Seal valve steam oil
16. RTV sealant
17. Coolant DEX-Cool Red
18. Valve exhaust
after they told me car is fixed i drive for 20 min and the temprature was below the middel after i park my car with few minutes the hose and the clamp explode again and all water comes out of the radiator again....... i know there is pressure proplem still with the cooling system but i don't know what else i need to replace after all of the long list above.
any body had same problem and fixed??
December 7th, 2010 02:00 PM #16
Yung extra AUX Fan is useful sa mga naka montero. Mag improve daw yung AC system since may extra...
