Results 1 to 14 of 14
    Sep 2005
    Guys, patulong naman po..
    hangin lang po yung lumalabas sa aircon, wala pong lamig. Pinacheck ko na po cya, yung compressor daw po mahina na. Then yung thermostat daw po sira. Option ko daw, may ilalagay cyang something (i dunno if thats the thermostat na) sa may dashboard, then hindi ko na daw makokontrol ung lamig ng aircon. Or kung gusto ko daw palitan na ung compressor.
    Ano po kaya problema?
    hmmmm... based sa description mo sa problem mo, i think you should check the freon level ng a/c mo. baka mamaya kulang lang yan sa freon eh. pa-check mo na rin kung may butas na ang a/c system mo, yung mga tubes niya. tama siya sa thermostat, pero depende pa rin yan, lalo na ang compressor.
    basta, unahin mo nalang mam yun freon level ipa-check. mind you po, what's your tsikot?
    from the description, it sounds like two problems.
    Compressor that doesn't compress anymore and busted A/C thermostat.
    The best route is to have both items replaced with similar parts. The compressor will be expensive. You can get it cheaper if you purchase from Banawe (there is a store there that sells car A/C parts). You can haggle the price but it will still be pricy. Cheaper option is to get surplus but this will be a hit-or-miss job because you don't know if the surplus compressor will last six years or six months before failing.
    Nov 2007
    manual thermostat ang ilalagay nila dyan mam pwede mo pa din iadjust yun paturo ka lang mam kung saan nila ilalagay yung slider or knob sa compresor naman pa check nyo po kung okay pa ang reading ng compresor alam ko pag nasa 50 naito medyo mahina na kailangan ito nasa 40 to 35
    btw mam saan ka nga pala sa taguig? baka magkapit bahay lang tayo
    yun! nakakita din si aga ng kababayan
    anyway po mam, kung ok naman po ang freon level and no leaks po, dun na po ang bagsak nyan, compressor and thermostat. thermostat is cheap, say 1k kasama na labor. pero ang compressor, brand new sa kotse, rough estimate ko is around 8-10k, which is very expensive. IMHO mam, get a brand new compressor para sure ka na tatagal yan ng years. just like sir gh said, eh hit or miss tayo sa surplus. HTH po mam!
    OT: seems that you're new here, we welcome you here in tsikot! welcome to tsikot family!
    Sep 2005
    thanks po for welcoming me :D
    sbe po kse nung mekaniko, pag pinalitan ko ung thermostat, hindi ko na papalitan ung compressor. so much better po kung palitan ko na rin ung compressor kasabay nung thermostat? sorry po ah, hindi po kse masyadong marunong sa kotse. gamit lang ng gamit hehee
    Sep 2005
    ok nman daw po ung freon, kse nung dinirekta nya, malamig naman po ung aircon. kotse ko po lancer 97.
    Dec 2007
    pareho tayo ng sasakyan 97 model manual gear din yung lancer ko at nangyari na rin sa aircon ko yung hangin lang ang lumalabas lalo na kapag naka low gear or nakahinto sa traffic light ng matagal.pinatingnan ko sa mekaniko at ang resulta kulang lang pala ang freon gas kaya mula nung pinadagdagan ko ng gas (2 months ago) maayos na ang lamig.
    Feb 2009
    Quote Originally Posted by yakanyaw View Post
    yakanyaw,
    before jumping into often wrong conclusion, have pressure tests done on your climate control system. the hi side usually reads at about 270 +/-10 psi and the low side will be around 27 +/- 2 psi. this will tell you the more or less complete story if your expansion valve is stuck open/closed and if the compressor has lost its ability. any trained technician knows this. these pressure specs are used for the R134a refrigerant. if your refrigerant is contaminated or is the wrong substitute, you can not use these pressure specs and the whole system be flushed to remove all traces of contamination. some of the refrigerants are not pure specially if it was recycled in a not so well maintained recovery/recycling/recharging machine. you have mentioned you had it topped off. there might be a considerable amount of impurities and moisture in the system. try to do the touch/feel checks and diagnoses in conjunction with the pressure tests.
    jick
    certified auto
    guam
    Sep 2005
    gusto ko nga po pacheck yung compressor ulit eh.
    so pag pinalagyan ko po ng manual thermostat ok na un? kahit hindi ko na palitan compressor? kaya lang yun atang ilalagay na manual thermostat yung parang nasa fx or taxi
    sir aga, sa tipas po ako. san po kayo sa taguig?
Air con problem.. wala pong lamig :(
