Results 1 to 9 of 9
    may honda ako yong aircon naga high pressure tapos naaapektohan yong idling? Anong best na gagawin???????tnx
    pls.. reply i need the recommendation badly!!!!!!!tnx
    pano mo ba nalalaman kung nag high pressure? aircon din kasi ng crv ko pag malamig ang panahon malamig, pag mainit naman mainit din. parang climate control na pabaliktad.
    Signature
    eljo,
    pacheck mo yung condenser fan mo baka mahina naikot nya or na stuck up na.
    Ganyan ngyari sa Civic ko dati... sira na pala yung condenser fan kaya nahihirapan yung AC. ...nagloloko tachometer needle. wag mo hayaan na ganun baka compressor pa madale.
    nachecked ko na fan okey naman maganda pa ikot, any other possible cause.
    palinis mo aircon.
    dapat once a year nililinis yan
    better do it asap bago bumigay ang isang parte diyan condenser or evaporator mas magastos
    Aug 2010
    Sir,
    Tagal na thread ito, pero pa share po kung paano naayos yung aircon nyo..
    Thanks in advance Sir.
    Share ko lang yung AC repair with my Adventure.
    Six years na yung Adventure sa amin, yearly ko pinapalinis yung evaporator, since walang cabin filter yung AC ng Adventure.
    Recently, hindi na talaga sya ganon kalamig. Kahit na bagong refill pa ng freon (actually 2x ako nagparefill).
    Pinapalitan ko yung expansion valve at dryer, ayun, bumalik na yung dating lamig.
    CMIIW, if you have your car serviced sa CASA, SOP na nila yung pinapalitan yung expansion valve and dryer. These two parts are wear-and-tear items, unlike the evaporator, condenser and compressor. The dryer is like an oil filter. Every time you have an oil change, pinapalitan yung oil filter. So ideally, everytime na pinapabukas mo yung AC, kelangan magpalit ka ng dryer dahil nacocontaminate ng hangin yung materials sa loob ng dryer.
    HTH.
    Sep 2011
    Hi mga bosing kung malapit po kayo s makati area sa kamagong st. cor. anubing st. hanapin nyo po ang RDC Car aircon repair shop
    or text nyo po sa # 09218059258 free check up & estimate po..hanapin nyo si Ronald..
honda aircon problem
