Results 1 to 10 of 17
April 28th, 2014 07:49 PM #1
Hi mga sir! My 90 rolla is at it again. I think I may have hose leak or radiator leak but help me with your thoughts.
May hissing sound sa driver side then bigla umaakyat temp to half even pag idle lang. Tuloy tuloy sya even kahit di tumatakbo. Drive 5km and almost red line na sa temp.
Nagtop up na ako ng coolant and i checked the pump. Mukang okay naman kasi nung una, reservoir lang ang nilagyan ko ng coolant. Pumasok naman sa radiator.
Please help. TIA
Samsung N9005 powered by Smart posted using tsikot mobile app
April 28th, 2014 08:39 PM #2
Check regularly your radiator water level kung nababawasan. If so, baka yung hissing sound na nadidinig mo is water dripping on a hot surface, e.g. Engine.
Posted via Tsikot Mobile App
- Sep 2008
- 596
April 28th, 2014 08:50 PM #3The hissing sound may indicate water is leaking most especially that you mentioned that you had to refill your reservoir tank. At times the leak is so small that you cannot see the water drop as the heat of the engine evaporates it quickly for you to see it unless you are observing it while the hood is open. Check all your hoses, and radiator (cooling system). There is definitely a leak somewhere.
April 29th, 2014 10:18 AM #4
nangyari na sakin yan, meron palang singaw sa may bandang intake manifold, hindi lapat yung gasket, pag uminit na yung water lumalabas doon yung singaw parang takure initan ng tubig
- Oct 2009
- 2,271
April 29th, 2014 03:14 PM #5kapag nilagyan ng coolant madaling ma trace kung may mga leak ang cooling system..kasi hindi siya kaagad natutuyo kagaya ng tubig.
paandarin mo at painitin saka mo silipin paligid ng makina kung saan dumadaloy ang cooling system mo..
April 29th, 2014 03:31 PM #6
:detective::detective::detective:
dagdag tanung din sa kasama nating bro tsikoteer tungkol sa hissing at high temp, napansin kodin wala naman tulo o tagas sa mga linya, pero nataas ang temp nya. sa akin kase normal ang guhit nya sa kalahati mag biyahe man ako ng malayo o ma trapik, pero kapag naka park at engine running kapag tumagal ng mahigit kalahati oras e tumataas ang gauge nya tapos kapag binuhusan na ang tangke ng tubig at reservior nya e nababa at nabalik sa normal. napansin ko lalo na ngayong pumasok ang tag araw palagi ganun, pero kapag tag ulan naman odi naman sha sobra init ng panahon e normal naman temp gauge nya. anu ba ere normal laang o may problema sa cooling system? mitsubishi adventure gas nga pala gamit ko..
April 29th, 2014 04:18 PM #7
if you hear the hissing sound at the driver side, it might be your brake vacuum booster that is leaking and adding false air (unmetered air into the intake manifold that was undetected by the airflow meter or MAP sensor or the MAF sensor). the added oxygen makes the air/fuel mixture lean and makes the engine temperature high. similar to the oxy/acetylene torch, if you add more oxygen, the flame turns light blue green and the temperature hotter. try disconnecting the vacuum hose to the brake booster and plug it to prevent a larger vacuum leak and to eliminate the possibility that the brake booster was indeed leaking air into the intake manifold
May 1st, 2014 05:46 AM #8
I give up. Di talaga kame magkta ng leak. Pero at least may idea n ako kung ano nangyayari. Thanks mga pogi!
May 1st, 2014 07:22 AM #10
For someone having experience working with Japanese team, I am sure they already anticipated this....
BYD Philippines
