Quote Originally Posted by izzy06 View Post
mga sir, is it true na pag high temperature ang compressor ay sira na 'to?
malamig kasi ang aircon ko kahit traffic, isang araw biglang may konting noise galing sa loob ng dash board pero di ko pinansin kasi malamig pa rin. Kinabukasan nung gamitin ko ulit nawala ang lamig. pinacheck ko ok daw freon pero high pressure ang compressor umaabot ng 90. SIRA NA BA ITO AT KAILANGAN NG PALITAN?
your high side (discharge) plays around 150-175 psi under philippine ambient temperatures. if you are using R134a, this pressure is normal and of course the compressor gets hot as the pressures rise so does the temperature. the suction side port of the compressor should be cool to the touch. at 90 psig on the discharge, possibilities are: low in charge(caused by a leak) or the compressor is worn out. have the system topped off first as a less expensive alternative to knowing if the compressor is going south
