Results 1 to 7 of 7
    mga sir, is it true na pag high temperature ang compressor ay sira na 'to?
    malamig kasi ang aircon ko kahit traffic, isang araw biglang may konting noise galing sa loob ng dash board pero di ko pinansin kasi malamig pa rin. Kinabukasan nung gamitin ko ulit nawala ang lamig. pinacheck ko ok daw freon pero high pressure ang compressor umaabot ng 90. SIRA NA BA ITO AT KAILANGAN NG PALITAN?
    90 psi in the high side is not high, time to look for another ac tech
    Feb 2009
    Quote Originally Posted by izzy06 View Post
    your high side (discharge) plays around 150-175 psi under philippine ambient temperatures. if you are using R134a, this pressure is normal and of course the compressor gets hot as the pressures rise so does the temperature. the suction side port of the compressor should be cool to the touch. at 90 psig on the discharge, possibilities are: low in charge(caused by a leak) or the compressor is worn out. have the system topped off first as a less expensive alternative to knowing if the compressor is going south
    Nov 2007
    tama sila sir...2 lang ang pwedeng dahilan..lose compression at kulang ng freon...
    thanks mga sirs pero kung sa freon ok pa baka nga wala ng compression kasi i went to 4 aircon shops all of them said compressor is busted since pressure goes up to 90 when rev.
    natural lang na umakyat ang high side lalo na pag nag rev ibig sabihin compressor ay ok. bakit kaya nasabi ng 4 na shop na sira ang compressor mo? maingay ba, how about the low side pressure, normal ba pressure at ayaw lumamig ang system? yung noise sa dash is most probably the ac blower.
    kung low side reads 90psi ,and high side reads the same ( 90psi)
    w/the clutch engaged * idle , compressor na nga ang sira .
high temperature compressor
