Results 1 to 10 of 38
September 26th, 2007 08:32 PM #1
1. Mga Peeps Ask Ko Lang What Brand Ng Coolant ang the Best Yet Affordable?
2. Pati Ba Sa Water Reservior, Coolant Din Ang Ilalagay?
- Jan 2007
- 4,459
September 26th, 2007 08:38 PM #2Oo nga, sa Mazda3 ko kasi wala ako nakita na lalagyan ng water for the radiator. Sa coolant na lang ba?
September 27th, 2007 09:40 AM #3
Tsikot Member Rank 4
- Jun 2006
- 2,605
September 27th, 2007 10:05 AM #4
April 15th, 2008 10:37 AM #7
I just buy from the casa, pre mixed na so no need to mix water, ratio etc...buhos na lang
April 15th, 2008 10:47 AM #8
Prestone 1:1 ratio with absolute distilled water including reservoir. * P230/li or P600/gal. nga pala claim ko yung prizes ko from prestone this fri. sa transhow - nang makapag pa-picture kay gaby dela merced :bwahaha:ayos na ayos ngayong tag-init.
- Jan 2008
- 380
April 15th, 2008 10:58 AM #9I use Top1 coolant sa isa kong car at 100 petot per can. I use only 1 can but change my coolant every 6 mos.
A 50/50 coolant mixture will only have 50% heat removal compared to 100% pure water. With less 'coolant in the mix' you have more heat removal capacity but for corrosion protection and lubricating properties a more diluted mixture needs to be replaced more often, which I am willing to do.
Radiator cap pressure rating should also be within your car specs or higher for increased boiling point, also to prevent hot spot formation, and pump cavitation.
I also use Shell and Caltex long life at 25% mix sa iba kong sasakyan. Wilkins (or kung ano mura na foodgrade distilled water) ang pinaka tubig ko.
April 15th, 2008 12:09 PM #10
I use dex-cool extended life 5yr coolant.... pero any coolant will do.
alas! for obvious reasons, they are sometimes the last available slots...
PH Gov't looking to bring back excise tax for...
