Results 1 to 10 of 38
September 26th, 2007 08:32 PM #1
1. Mga Peeps Ask Ko Lang What Brand Ng Coolant ang the Best Yet Affordable?
2. Pati Ba Sa Water Reservior, Coolant Din Ang Ilalagay?
- Jan 2007
- 4,459
September 26th, 2007 08:38 PM #2Oo nga, sa Mazda3 ko kasi wala ako nakita na lalagyan ng water for the radiator. Sa coolant na lang ba?
September 27th, 2007 09:40 AM #3
Tsikot Member Rank 4
- Jun 2006
- 2,605
September 27th, 2007 10:05 AM #4
April 15th, 2008 10:37 AM #7
I just buy from the casa, pre mixed na so no need to mix water, ratio etc...buhos na lang
April 15th, 2008 10:47 AM #8
Prestone 1:1 ratio with absolute distilled water including reservoir. * P230/li or P600/gal. nga pala claim ko yung prizes ko from prestone this fri. sa transhow - nang makapag pa-picture kay gaby dela merced :bwahaha:ayos na ayos ngayong tag-init.
April 16th, 2008 12:33 PM #9
- Jan 2008
- 380
April 15th, 2008 10:58 AM #10I use Top1 coolant sa isa kong car at 100 petot per can. I use only 1 can but change my coolant every 6 mos.
A 50/50 coolant mixture will only have 50% heat removal compared to 100% pure water. With less 'coolant in the mix' you have more heat removal capacity but for corrosion protection and lubricating properties a more diluted mixture needs to be replaced more often, which I am willing to do.
Radiator cap pressure rating should also be within your car specs or higher for increased boiling point, also to prevent hot spot formation, and pump cavitation.
I also use Shell and Caltex long life at 25% mix sa iba kong sasakyan. Wilkins (or kung ano mura na foodgrade distilled water) ang pinaka tubig ko.
When does that happen? 1. During starting? 2. While the vehicle is idling/running?
ALTERNATOR. Repair or replace?
