Results 31 to 35 of 35
January 23rd, 2013 03:32 AM #31
saan bang shop maganda magpacheck ng leak?? sakin naman sa reservoir lagi nagbabawas... na-top overhaul na din kasi makina kaya sabi normal daw magbawas tubig.. totoo ba yun??
- Jul 2010
- 570
January 24th, 2013 09:56 AM #32Ano ba gamit mo sa radiator mo? Coolant or ordinary tubig lang. Every gamit ba ng kotse ay bawas kaagad ang reservoir?
Kung maganda pagka Top Overhaul sa engine ay dapat hindi mag leak ang coolant sa loob ng engine.
January 24th, 2013 08:00 PM #33
- Aug 2005
- 553
January 29th, 2013 01:53 PM #34There are very finite causes of leaks unless your radiator itself is damaged.
Check the following:
1. Inlet hose and attachments from the engine to the radiator.
2. Outlet hose and attachments from the radiator to the engine.
3. Radiator cap.
4. Thermocouple O-ring.
5. Overflow pipe.
6. Water pump.
If no leaks are visible, check your radiator for leaks, tanks, headers, core.
If no leaks are found there's a good chance its leaking into your engine. So check your oil.
Once you find and seal the leaks, flush and refill your system with coolant mixture and clean water.
January 29th, 2013 02:29 PM #35
check mo ang water pump, meron itong weep hole baka doon lumalabas, kailangan lang mainit na ang makina bago mo inspect ito para makita kung meron leak.
Edsa is about 24kms long. So, 15b / 24 is approx 625m per km?
EDSA Rehab/Rebuild and Guadalupe Bridge Repair
