Page 1 of 2 12 LastLast
Results 1 to 10 of 14
    Nov 2004
    Help naman i've got overheating problem here's the story
    Overheat then check fan not working put water to cool it off then went to Evangelista when I arrived there the fan is working na grrr.
    Sometimes I have problems with starting it parang walang contact but after a few clicks with the key oks na he he
    Sometimes then when I have my aircon on nag over heat din pinatay ko ok naman. Parang erratic ung prob.
    Went to shops to check both fans oks naman hu hu . I insisted to check the aircon system they just gave me remarks blah blah nothing about overheat
    i have an lancer 96 pala
    Sep 2005
    Icis:
    ur problem is overheating right? kapag umaandar ba ang aux fan mo wether naka aircon ka or notm nag o overheat pa rin ba ang kotse mo? if ur answer is no, then its simple, may problema ang aux fan ng kotse mo. minsan kase hindi mo nakikita na biglang hihinto ang aux fan nito.
    isa sa mga cause nito is baka ubos/maiksi na ung carbon brush ng aux fan or may naglo loose na contacts somewhere sa wiring ng auxillary.
    so i suggest u have it checked thoroughly. pabuksan mo kung nararapat para makita mo talaga ang problema.
    parehong aux fan ba ang humihinto?
    may also want to check yung thermo switch. its usually located dun sa lower part ng radiator. sya yung nag sense ng temp ng water inside, tapos pag na reach na yung set temp. mag switch na sya.
    Intermittent talaga ito pag malapit na bumigay.
    Aug 2004
    Naka-on ba both fans mo kung naka-on ang aircon? Malakas pa ba ang buga ng hangin ng fans?
    Happened to me before. Namatay aux fan ko. Punta Evangelista para palit aux fan motor. 500 ang motor 100 ang labor. No more overheating problems kahit trafik at tanghaling tapat.
    May starting problems din ako dati. Minsan 7 clicks muna bago mag-start. Pinalagyan ko ng relay. 1 click start na uli.
    Nov 2004
    Tx for the fast reply guys anywaz some more details:
    Da Evangelista boys check both fans and they declared it malakas naman, I almost argued with them na may problem about overheat and insisted them to check it.
    I was really pissed about the problem
    I’m thinking na baka contacts nga but WHERE coz , the aircon turn off I am experiencing overheat still. There was this one time when I am almost about to overheat just when I noticed it I just went to side of the road and cool it off and afterwards shut off the engine. After a while turn on the engine I drove again aba ok wala na overheat.
    I have a new Bosch relay nga pala
    Please do help!
    Aug 2004
    So kahit di ka nag-aircon overheat pa rin? When was the last time you replaced your waterpump?
    thats it. water pump na nga yan
    Aug 2004
    Kung water pump I suggest you replace your timing belt, tensioner bearings and cam and crankshaft oil seals para isang labor charge na lang.
    OEM
    timing belt - 2300
    tensioner bearing - 800
    cam and crankshaft seals - 250 each (500 total)
    water pump
    replacement (GMB) - 1100
    OEM - 4000++
    labor - 1200++
    Nov 2004
    thanks for the suggestions
    i am just curious the problem is not always occurring. Why did the radiator fan not functioning during when I am overheating but sometimes ok naman ?!
    Oct 2004
    Icis.. please read the article http://www.troubleshooters.com/tprom...210/200210.htm
    Lalo na ung Summary and conclusion sa bandang baba ng article. Hope it helps.
Help overheat problem
