Results 1 to 6 of 6
February 11th, 2007 03:26 AM #1
mga kapatid tulong naman we have a hi ace from subic yung super custom na may over heating problem napalitan na namin ng cylinder head and head gasket pero nag oover heat pa rin sya any suggestion kung ano pang pede naming gawin and saan namin pedeng ipagawa?salamat......
February 11th, 2007 05:18 PM #2
here some cause of overheating:
thermostat?
water pump?(check circulation of engine coolant)
minsan radiator cap lang or radiator fan(clutch fan, sa unang start kailangan gumagana siya or maingay)
clogged somewhere (check hoses or radiator)
February 11th, 2007 05:19 PM #3
pina-genaral overhaul/cleaning(top-bottom is removed) mo na ba radiator?
papalitan mo ng labi nung pinaglalagyan ng pressure cap?
sure walang tulo?
how about the hoses, ok pa ba or marupok na?
is the there a leak somewhere?
is the theremostat ok or stuck-up?
does your aux. fans ang your clutch fan works well?
nga pala, matic ba ride mo? baka signs of deteriorating A/T na yan, palitan mo ng ATF.
forgot nga pala, is the water pump pumping with enough pressure?
February 11th, 2007 08:04 PM #4
thanks guys for the reply's halos lahat nung cnasabi nyo nagawa na namin mukang kailangan na namin dalhin sa ibang mekaniko lahat kasi ng na mention nyo na pedeng maging problem naitanong ko na sa mekaniko namin sabi naman nya oki pa raw.....can you guys recommend any shop na pede kong pagpagawaan?
February 11th, 2007 09:45 PM #5
tama, baka kailangan palitan mo na mekaniko mo....saan ka ba, sa visayas ave, QC may kilala akong kaya gawin yan(kasi meron silang ganyang service,e) "reynalie" ung shop,from QC circle, lagpas ng montisorri, after ng 2nd tulay, uturn sa slot sa tapat ng caltex, the pabalik ka ng konti, lagpas ka ulit ng tulay, ung shop dun sa rt side mo, dun ako nagpapagawa din nung liteace ko.(jdm din po ung akin.)
February 11th, 2007 10:36 PM #6
salamat alwayz yummy malayo pala dto pa kasi ako sa laguna meron pa ililipat ko na nga ng mekaniko kapag nde pa rin naayos bka dalhin ko dun sa sinasabi mo
Megawatt charging: https://www.youtube.com/watch?v=usUxO7y4z_E
BYD Philippines
