Results 11 to 20 of 26
November 7th, 2012 09:14 AM #12
mga sir nilagyan ko ng asphalt ung belt dina nag slide gumana na uli a/c ko.
ano kaya ang sira mga sir?
November 7th, 2012 10:08 AM #13
baka naman luma na yung ac belt?
sa akin, mas ok pa din palitan yan... baka maputol eh.
November 7th, 2012 11:14 AM #15
November 7th, 2012 11:23 AM #16
- Nov 2008
- 641
November 7th, 2012 11:27 AM #17Bossing,
Most likely its a bearing or other mechanical compressor failure. Better have it repaired immediately as it might cause more damage to your compressor as well as other connected parts. Usually, the freon has to be removed as the compressor has two bearings located at both ends. Better have it estimated (after dismantling) so you may have an idea if its more feasible to repair or replace.
Cheers!
- Jul 2010
- 570
November 7th, 2012 12:13 PM #19Korek sina jvnj at ID4LV
Pa repair mo kaagad bago umikot yun buong casing ng bearing sa casing ng aircon compressor. Hindi mo dapat nilagyan ng belt dressing yun belt. Hindi na dudulas ang belt. So ang tendency ay maputol ang belt or sirain ng stuckup bearing ang aircon compressor.
Ito magastos mo kung magpapalit ng bearing:
Freon ang labor charge ng aircon specialist 1,200
Bearing= 500.00
total cost of 1,700
Ito naman kung nasira na yun casing ng aircon compressor"
Aircon Compresor price depends on brand. Lets say 8,000.00
Total cost 9,200.00
Pili ka na lang alin dyan ang gusto mo. Kung ako sa iyo ay tangalin ko muna ang belt bago ma-disgrasya iyan aircon compressor.
- Nov 2008
- 641
November 7th, 2012 12:16 PM #20Bossing,
Assuming that its the bearing only (defective), I would suggest that you replace the seals as well as it might leak sooner or later, this will save you more on labor, refrigerant oil and freon.
Goodluck!
Xiaomi E-Car
