Results 1 to 10 of 10
January 12th, 2004 05:25 PM #1
Multiple Clicking sound on the compressor when the car on stop or idling..please do help before going to the ac shop.
Pero pag naka go naman ok lang sya.Bago ang radiator coil so di naman dun ang problem wag lang ang compressor sana.
Hindi naman ganito dati.usually 1-2 clicks lang pero ngayon ang dami na please help wala pa naman akong pera ngayon huhu..:confused:
My ride is a corolla xl97 all stock.
January 12th, 2004 05:33 PM #3
Okay, i've experienced that before. rapid clicking of the compressor while engine is on idle. But in my case there was really a big problem with my A/C.
Since bago evaporator, di kaya sa thermostat na nakakabit dun evaporator mo? hmmm.....
January 12th, 2004 05:58 PM #4
try adjusting your thermostat. baka dun lang ang problema. mukhang sira ang thermostat mo kaya nalilito sya kung io-on or off nya ang compressor.
January 12th, 2004 06:17 PM #5
sana nga dun lang.dont know how to adjust it or dalhin ko na sa a/c experts.
January 12th, 2004 08:32 PM #6
i suggest that you bring it to an a/c shop (i highly recommend frigid zone in kamias). then watch on how they work on your car and don't be afraid to ask questions.
January 12th, 2004 09:22 PM #7
If your compressor is clicking, baka yung magnetic coil mo yun. Php 800.00 yun kay Mang Mario. Another Php 800.00 ata for labor and materials.
Thermostat is the slider switch on your dash. Wag mo i-set sa todo cold. Try mo 3/4's lang.
January 13th, 2004 02:19 PM #8
salamat po mga master.will try to bring the car after sahod hehe.ubos na pera e.more powerssssssssss sa inyo!!!!!!!!
- Nov 2002
- 29
January 13th, 2004 03:02 PM #9kailan ka huling nagpalinis ng evaporator? Baka sobrang dumi na at kailangan ng palinis. ..1000 ang linis ngayon para sa corolla.
- 3,754
January 13th, 2004 04:07 PM #10Check mo ang FUSED.... baka maluwag lang or sunog na ganyan nangyari sakin minsan gagana nimsan hindi tapos grounded na electrical kaya pala ang sunog ng fused...on and off ang compressor
So what's wrong with increased coolant concentration? The cooling capacity mostly comes from water,...
Coolant...
