a breadloaf van? where the driver sits on top of the engine?
i tried many things. none worked well enough. i finally got rid of the van, and bought a vehicle whose engine is in front of the driver.
first thing you should see to, is the factory-spec covers. make sure they are intact, with no deformations or openings or missing bolts.
i tried those aluminum-backed insulating sheets used in house roofing. it lowered the heat naman, but still not satisfactory.
i don't like to use fiberglass in a moving, vibrating vehicle. the 'glass needles might aerate and get inhaled.
and the traditional heat insulator, asbestos, is a proven carcinogen.
ditto on using fibreglass
maybe he can try using slimmer but layered double sided insulation "foam"
