Results 11 to 12 of 12
- May 2006
- 78
October 21st, 2007 05:59 PM #11Nagkaganyan din A/C ko. Last week may umiingay sa engine bay even with or without A/C. Di ko lang ito pinapansin. Tapos kahapon may grug-grug na sound , di ko pa rin pinansin. Tapos kanina may whistling sound na pinansin ko na sya. In-isolate ko muna yung belt ng aircon tapos sabay baklas na rin ng idler pulley. Nang paikutin ko manually yung idler pulley yun pala ang pinagmumulan ng ingay. Pinaandar ko yung engine wala ng ingay.
Naghanap agad ako ng malapit na auto supply kaso sunday halos lahat sarado na, ginawan ko na lang ng paraan, tinanggal ko muna yung seal ng bearing in one side tapos lagay ng high temperature grease para magamit ko lang bukas sa work para may aircon parin. Ok naman ang takbo pero papalitan ko pa rin yun bearing pag nabakante na ako.
October 25th, 2007 12:18 AM #12
thanks sa lahat ng replies, i had my sister do the starting while i was observing the engine, i saw this line connected from the condenser to the compressor vibrating badly. so binalik ko sa shop tas tinuro ko sa kanila, they made some adjustments tas nawala. hinigpitan lang daw nila tas medyo bawas ng freon kasi napasobra daw. weird di po ba? kung maluwag yun eh di sana nagleak na lahat ng freon ko. anyway nasolve naman so that's a relief!
soy-based wire insulation. 1. cheaper than the petroleum-based plastic insulation. 2....
BYD Philippines
