Originally Posted by
yebo
yup do a search meron na thread about that.
but to make it easier for you, yes a thermostat is necessary. those mechanics who say that it isn't do not know what they are talking about. having a properly functioning thermostat in your engine will do the ff:
1. shorter warm up times. the shorter the warm up the earlier the engine will reach its efficient temperature. also shorter warm ups lessen engine wear. the reverse is true also, without a thermostat the warm up times get longer and leads to more engine wear due to the engine parts not being in its optimum operating temperature.
2. a thermostat regulates the flow of cooling water between by-pass (meaning the coolant does not pass through the radiator) and the radiator, keeping the optimum operating temperature for the engine at all times. removing the thermostat will permanently divide the flow of water between radiator and by-pass. that means the cooling efficiency of your radiator is actually cut by 50% and this could in fact lead to engine overheat.
