Results 1 to 2 of 2
- Apr 2011
- 20
May 29th, 2011 09:51 AM #1Guys,
Di na po gumagana yung gauge temp ng auto ko. Corolla bigbody po siya. Anu po kaya magandang gawin? Thanks!
May 30th, 2011 06:36 AM #2
try disconnecting the temp gauge sending unit, the dash unit should respond either indicating false overheat or cold engine. if it does, the sending unit is the defective part. if it does not, try removing the instrument cluster, and mechanically exercise the gauge needle. these dash units gets stuck after a few years from the heat of the sun and ultra violet rays
so i looked under the two twist-beam cars i have here. wala talagang weld sa top and bottom. and...
Chery returns to PH
