try disconnecting the temp gauge sending unit, the dash unit should respond either indicating false overheat or cold engine. if it does, the sending unit is the defective part. if it does not, try removing the instrument cluster, and mechanically exercise the gauge needle. these dash units gets stuck after a few years from the heat of the sun and ultra violet rays
