Results 1 to 10 of 11
February 8th, 2008 10:18 AM #1
hi peeps i have a gas mitsu adventure 2000 model i notice its fast rising temperature upon starting the engine it takes a matter of 2-5 mins for the level to reach the center even if my car is parked (engines on) and ive done no revs yet is this normal?
ive replaced its coolant already.
- Jan 2008
- 154
February 8th, 2008 10:32 AM #2baka clogged na ung ibang parts ng radiator mu or baka marumi na ung bottom part ng radiator kya ayaw mgflow ng maayos ung water.. try full draining the water
put running water so that it can help cleans the radiator
pag di pa din ok yan overhaul na ng radiator need nyan or a new 1
is the other fan working well? check mu din baka di na cya ngautomatic
February 8th, 2008 10:40 AM #3
I think this is the time it takes for it to reach its optimal operating temperature. Has your engine reached a point beyond the center of your temperature gauge, or has it overheated? If you answered no, then I think what you are experiencing with your mitsu is normal.
February 8th, 2008 10:42 AM #4
bro salamat sa info ok nmn yung fan, madumi na nga siguro yung rad. wla rin nmng leak, water pump n nga yung naisip kong problema nun e.
- Jan 2008
- 154
- Jan 2008
- 154
February 8th, 2008 10:56 AM #7ganun,,, normal yan.. but if di yan ung usual temp na nakikita mu pag gamit mu cya? linis lng yan tol, after that it will be just fine again
February 8th, 2008 10:58 AM #8
Ganyan talaga ang mga bagong makina. Pag nag on ka ng makina, medyo mataas ang rev (nasa 1000 to 1500 rpm) para agad mag init ang makina. Pag mainit na (iyong needle ng temperature gave ay nasa typical position) bababa na ang tach to less than 1,000 rpm.
Pag di pa mainit ang makina, di pa masyadong nakakaikot ang oil sa loob ng makinaat di pa optimal ang combustion.
As long as di masyadong lalagpas sa typical na puwesto ang needle ng temp gage, ok lang.
- Jan 2008
- 154
February 8th, 2008 11:01 AM #9dati nga pumunta ko tagaytay muntik na ko magoverheat maliit kc ung radiator ng lancer ko, but i replace it with a 3rows radiator pinakamataas na temp na mkuha ko belo sa haf tpos kapag matulin takbo bagsak temp nya parang di umiinit makina
February 14th, 2008 10:58 PM #10
bro meledson salamat sa info
at least medyo kampante na ko bumiyahe. mdyo long distance kasi route ko. at least normal naman kahet gano na kalayo the pointer is still at the mid.
A 70/30 water to coolant mix may improve cooling efficiency but that's at the cost of less...
Coolant...
