Results 1 to 4 of 4
- Jul 2011
- 27
September 2nd, 2011 01:41 AM #1recently ako nag post about dun sa odor issue.. nyway ayaw po gumana nung blower,fan nung AC yata..
tried switch 1-4 meron naman nafefeel na cold breeze or feeling coming from the vents pero the fan isnt working yata.. there was one time parang tunong fan belt na maluwag tunong nung fan and somewhat nahihirapan ata umikot.. is there a way DIY mode? or on video sana..
its a civic EK po..
September 5th, 2011 11:29 AM #2
using a multimeter (set to 20V):
backprobe on the fan connection (i.e. - connected to nearby ground & + to the motor connection). if you see 12V, wiring is good.motor is bad and could be due to worn out brushes. well that depends on the switch location (negative or positive grounding). you see 12V fulltime on ground side switches. you may hotwire from the battery positive to the motor. if it spins, wiring is bad.
another thing to for is the resistor block located at the air stream downstream of the blower. if the fan burns out, there's a possibility that this resistor block is also burnt as this part dissipates a lot of heat that's why it is located at the airstream in the blower assy.
for sealed motors, go for a good replacement or surplus part.
be ready to get sleepy under the dash...hehe
- Jul 2011
- 27
September 6th, 2011 09:40 AM #3tnx sa info.. i got it fixed na po.. may pinalitan lng ung mechanic na parang fuse na malapit dun sa battery..
September 7th, 2011 11:01 AM #4
oo nga no. di ko naisip yung simpleng fuse...but if the fuse blows again, there is a problem somewhere on the wirings.
I went with him at LTO's The Link satellite office nung nag-renew sya. We were given a number to...
