Originally Posted by
miked
Check also hose integrity... the 2 hoses may be failing especially lower hose. upper hose is under pressure and hotter while lower hose is cooler and for suction of water from rad to engine. since uphill climb therefore high rpm ang engine and so is the water pump thus creating vacuum at water jackets.
plus the fact that your transmission is internally cooled by the engine rad, i think it's normal for the temp to go up since the A/T is working harder on uphill as compared on level roads
