Results 21 to 40 of 48
    May 2012
    #21
    I didn't say put ABOVE 50%,, 50/50 kalahati distilled water Kalahati coolant.
    Apr 2009
    #22
    Quote Originally Posted by glxexurb View Post
    Helo po mga katsikot,sasakyan ko ay toyota liteace 2c-turbo diesel.kahapon may outing kami at puno po kami 13 pasaheros.,halos 5 kilometro po byahe na puro paakyat kalsada,ngayon tumaas po temperature gauge nya sa halos malapit na sa letra H na kulay pula guhit.tumigil ako para magtubig,hindi naman halos nawalan nang tubig ang radiator o halo wala pang isang litro dinagdag ko.ang tanung ko ay okay kaya kung maglagay ako nang engine coolant?purong tubig lang kasi ang nilalagay ko sa radiator at sa reservoir nya.hindi na kaya cya iinit o tataas temperature gauge o normal lang kung overload sakay mo?ramdam ko kasi mabigat karga ko na 13 katao.salamat sa mga inputs
    Your LiteAce probably is a surplus Japan as no LiteAce with 2C Turbo was issued here in the PI by Toyota. Anyway, cars usually meant for countries with snow usually has "thinner" radiator than cars issued for tropical countries. So in essence, your liteace is being "undercooled" more especially since it is turbo - charged as heat transfer between your radiator and engine is inadequate. One remedy you can do is to swap in a 3-4 row radiator to your liteace
    #23
    Quote Originally Posted by LN106G View Post
    Tama ka Sir (i agree) yung lite ace nga nya is Japan design for cold countries sigurado din ako na maliit ang capacity nung radiator nya (2 rows lang cguro at maliliit pa yung butas) im sure 100K km na yan tangalan mo na rin ng thermostat at palit ka ng radiator yung Evercool para tropical design. coolant 50% and Distilled/purified Water not mineral 50%. that will solve your problem.
    #24
    Apr 2014
    #25
    Quote Originally Posted by BoostBoy View Post
    Coolant will probably better than water alone only, and you can mix it with distilled water. Tap water can cause rusting inside your radiator. Matindi din sa liteace yung paakyat tapos punong-puno.
    Just don't use tap water. dami minerals at other metallic ions from the pipeline na kasama. Buy a gallon of distilled water and mix the recommended coolant for your unit following. then yun ilagay mo sa cooling system.
    Apr 2009
    #26
    Quote Originally Posted by Diesel_Torque View Post
    Just swap in a bigger radiator but do not remove the thermostat. Replace it with a new OEM if defective....
    Apr 2009
    #27
    #28
    now, why would you want to remove the thermostat? what it do to you?
    Mar 2015
    #29
    eto need ko eh
    #30
    ^^^imho, ang thermostat pangcontrol ng coolant flow sa engine block (water jacket) at sa radiator to maintain optimum temperature ng engine.
    Not advisable to remove and / or irekta din ang fan.
    Tinry ko sa civic ko yan, pero parang hirap makina dahil malamig pati oils niya. Hihihi.
    May 2009
    #31
    tangalan mo na rin ng thermostat. that will solve your problem.
    no no no....it will compound the problem.
    kakabenta ko lang pickup ko sa tito ko. diko sinabi na may thermostat akong nilagay......baka kasi tanggalin nila. hehehe.
    Jun 2014
    #32
    Guys ask ko lang, naglagay ako ng coolant sa reservoir kaso may natapon kc un funnel (coke sakto) malaki pa un butas nya. Natapunan konti un ilalim May affected kaya na area sa engine pag ganun?
    #33
    Quote Originally Posted by _incubus19 View Post
    wala yan bro....
    wala yan bro....
    Jun 2014
    #34
    Thanks sir
    Jun 2014
    #35
    If papalitan un coolant, db drain lang un sa reservoir? Pati ba un sa radiator matanggal din? How is the proper procedure? I'll be using toyota super long lofe coolant (pink) pre mix. Ndi naman ako un magpapalit but gusto ko lang malaman anu tama procedure. Need parin ba lagyan ng tubig un radiator after idrain un coolant sa reservoir? Or un coolant lang since pre mix naman sya 50/50. Thanks
    Mar 2015
    #36
    Ang proper procedure nyan kailangan po matanggal lahat ng contaminants sa loob by flushing.meron nabibili na radiAtor flush na hinahalo.tatangalin m un thermostat para maganda ang flow then i idle m sasakyan ng 30-40 min tapos idrain m sa may petcock sa ilalim na gilid ng radiator.gawin ito ng ilang beses hangang mag clear yun tubig.distilled water gamitin hindi yun tap water kasi meron din particles yun.tapos ibalik ang thermostat,iclose ang petcock drain valve at magrefill na ng coolant.paandarin m makina para maiburp nya un hangin sa loob.this time make sure to check temp gauge kun sakaling mag overheat.kasi wala pa laman n coolant sa may block pag hindi pa nag oopen yung thermostat.pwede m siya idrive at palamigin ulit makina bago icheck yun level.pati reservoir dapat lagyan m rin hangang sa max level lang para my space for heat expansion
    Mar 2015
    #37
    para mas confident ka gawin watch on youtube how to flush cooling system.goodluck
    Mar 2015
    #38
    Ang nakakasira ng radiator ay pag tubig lang ag ilalagay.tignan m yung takuri pag laging pinapakuluan ng tubig meron naiiwan residue sa loob.at pag tubig kakalawangin yan.at sa thermostat naman importante din po yun para mas madali mag warm up at mamaintain yung operating temp ng makina.hindi kasi ok pag malamig makina.mas aaksaya ng gas at mas hihina performance.yun parang cold start lang sa umaga.xempre nakakatulong din yun lalo na sa manga nagmamadali.pag wala kasi thermostat tuloy tuloy na ang daloy ng coolant kya parating malamig makina.mahirap nya kunin yung operating temp.palitan nalang po kung sira na.at pwede m din linisan radiator fins bombahan m ng tubig.pag clogged kasi yan ng bugs,dirt,leaves etc.hindi natatangay ng hangin yung init.
    Feb 2009
    #39
    Questions like this, please go to google. If you are not satisfied, ask here. I'm sure if no one has a ready answer he can get you one in 24 hours.
    This question and the like are so redundant people are just too lazy to do research. You don't need to go to the library as long as what you have now "internet"
    Mar 2015
    #40
    Orayt!rock and roll to the world mga tsong! Chilax!
Engine coolant,kelangan ba?
