Results 11 to 17 of 17
June 16th, 2007 05:24 PM #11
tanung ko lang po, bakit ung aircon ng sa min, mb100, yung a/c sa harap mas malamig yung hangin kesa sa a/c sa likod?
June 17th, 2007 12:58 PM #13
kung faulty yung expansion valve sa likod, maarin din humina lalo ang lamig dun sa likod...
- Apr 2007
- 19
June 20th, 2007 03:34 AM #15taning ko lng din, normal po ba na mabawasan yun lamig ng front ac pag binuksan un sa likod? kasi ok po lamig nun a/c ko sa harap pag naka off yun rear, pero once na buksan un sa likod, nawawalan ng lamig un sa harap.
June 20th, 2007 08:46 AM #16
pwde lalo na kung mahina na ang compressor mo..ganyan prob ng van ko,e... wala pa kong budget pangpalit ng compressor,e...kasi as a rule, pag nagpalit ka ng compressor, dapat general flush ng system para di maipon sa compressor yung dumi ng system...
- Aug 2007
- 675
September 20th, 2007 01:43 AM #17Does the ceiling mounted blower make a difference? Kapag tapat sa araw masmainit ceiling and the rear aircon blower is mounted on the ceiling, kaya baka masumiinit yung hangin bago ito lumabas.
Also, masmaraming air outlets yung aircon sa likod and so the blower's strength is divided per outlet kaya masmahina yung labas ng hangin thus less ang cooling as compared to the front which has only about 4 air outlets.
as above, if you want to go OEM-style, get a "spare tyre lock". but i use an ordinary cheap...
