Results 1 to 20 of 35
    Apr 2006
    a thread i found at hcp from emong3:
    Summer na naman at mukhang painit ng painit ang summer sa Manila... Every year mas mainit keysa previous.
    Here's a simple project you can do to your Aircon to make it a little more efficient.
    Materials needed:
    1. Spray bottle (yung pang wisik ng tubig sa mga barbero)
    2. Windshield washer hose
    3. Zip Ties
    4. Epoxy steel
    Procedure:
    1. Cut the nozzle of the spray bottle using a hack saw. ghetto rig the hose so it will connect to the nozzle. use epoxy para matibay.
    2. Position the Nozzle on front of the Condenser and secure it using zip ties.
    3. Un plug the windshield washer hose from the pump, and connect the hose from the nozzle.
    Principle behind this:
    During hot weather, the ambient temperature is so high, the heat transfer in the condenser becomes less efficient. Spraying a mist on the condenser improves the transfer of heat from the condenser to the air. Heat is required to evaporate the water thus heat transfer is improved.
    Di naman nag uuulan pag summer kaya bihira lang gamitin ang windshield washer. During hot days and you are stuck in traffic spray a mist of water on the condenser para lumamig siya and you will notice lalamig din ang aircon mo at mas maganda ang idling ng kotse...
    HTH
    Apr 2006
    from necatur of hcp:
    post ko lang po yung ginawa ko sa Esi ko, in honor of Papa Emong, the great DIY master <---- idol ko to....
    materials needed (my version) old windshield mist washer nozzle + barena + washer tube
    Apr 2006
    continuation of necatur's post:
    process medyo malaki yung base nung old washer ko kaya binakli ko
    Jul 2006
    Maganda sana kung atomized yung spray para kalat yung buga kaysa sa standard windshield washer nozzles na stream of water yung buga niya.
    Apr 2006
    yep. yung "wide" spray sana like the ones sa picture.
    have tried doing it yesterday. used the wide spray. kaya lang ang problem ko masyado atang malapit kung sa bumper ng car iinstall. the nozzle does not have enough distance from the condenser to spread/disperse effectively.
    btw, sa mga gustong gumawa nito, you can save a lot by buying the hose from the petshop. meron din silang "splitter" for these hoses.
    Apr 2009
    Quote Originally Posted by mbeige View Post
    Quote Originally Posted by wewoy_romero View Post
    Pano po gawing wide spray? Pag dinikit po ba yung nozzle dun sa hose automatic wide spray na?
    Yung atomised/pakalat na spray po diba kelangan pa ng pressurised air para maging pakalat yung buga?
    Yung nagawa ko po kasi hindi pakalat yung spray eh.
    Thanks.
    Jun 2005
    gusto ko yan! basta diy panalo yan!!!
    I just stop by a gas station and pour some water through the grille/bumper instead hehe. But luckily, my A/C doesn't need extra cooling.
    Feb 2011
    baka pwede po ito, micro mist nozzle from wilcon 1371-20 MICRO MIST NOZZLE - Wilcon Builder's Depot at Spray Nozzles Especialist Philippines - 1935631 specially yung image #4
    Aug 2005
    Here's a simple tip.
    Blow air through your condenser and radiator to dislodge any dust/debris that have accumulated.
    I would be cautious about getting your radiator/condenser wet as you may end up clogging it with dirt when water mixes with dust and dries.
Diy Pampa Lakas Ng Aircon!, Beat the summer heat...
