Page 1 of 2 12 LastLast
Results 1 to 20 of 22
    mga sir,, may problema ako.. kada every end of the month, yun Coolant nauubos.. this is not normal. I have 2 rav4s.. yun isa binili sa casa bnew.. then yun isa 2nd hand binili ko.. same model but different lang kulay. yun 2nd hand rav ko may leak sa tingin ko kasi nauubos agad coolant nito within a month! yun isa kong rav, 1 year na hindi pa nauubos coolant kahit todo aircon nito.
    patulong naman po mga sir... ano ito bibili ako bago radiator kasi nakaka-370 a month din yun coolant na binibili ko sa Caltex.. ano ba solusyon dito? nanggaling yun tumutulo sa radiator.. tapos at the end of the day, bawas na coolant level ko from full na halos paubos na..,,
    salamat..
    May 2007
    Hmmmmm! No leak.
    Check oil for coolant would be foamy inside of oil filter if its there you have leaking head gasket. Could have been a bad heater core or hoses dahil mahirap makita yan kung minsan. Check the lines from motor to fire wall and if you can see stain of water. wet carpet or look under car if coolant are presence then trace the problem. Also check yong mga connection ng hoses sa radiator, top of radiator along spout, if can see any presence of coolant baka may leak na maliit since you have said na nawawala in about a month.
    Heres some hence, put a cardboard box under your engine after you park your car. overnight. Kapag may tulo tiyak na makikita mo sa kahon kung saan nangagaling ang leak.
    Jun 2006
    Did I understand you correctly that you already found the radiator leak? If yes then you can have it repaired at radiator shops. Or if you have the funds, just replace it with an Evercool radiator.
    If you cant find the leak, start by checking your radiator hoses. If your hoses are ok and no visible leaks under the car, replace your radiator cap.
    Check water pump water drops sa cardboard. Remember, w.pump will only leak when its not in use.
    Another way is put a water hose sa radiator openning and then pressurize the system, look for leaks on the hoses, clamps, gaskets.
    Sep 2004
    Kung medyo newbie ka pa, just bring it to a radiator repair shop, and let them worry about finding the leak. But if you want to go the DIY route, observe the engine bay while the car's engine is running. Have someone rev the engine, kasi usually sisirit yung tubig kung may leak. Check mo rin yung hood mo kung may water marks. Dried coolant will leave a tell-tale mark. Usual suspects naman are hoses (main and bypass) and a leaky water pump.
    Mura lang ang top overhaul ng radiator, mga P450-500. Rad shops naman will tell you if its no longer repairable, and will advise you na lang to buy a brand new one.
    Quote Originally Posted by kicks4us23 View Post
    salamat..
    replace your radiator then....
    Replace your radiator na lang. In the meantime, just use plain water na lang since you already have a leak - sayang lang ang coolant.
    I think Speedyfix & Speedlab carries Evercool radiators.
    The OEM radiator assembly for the Rav4 (Gen II) costs around P38K. :shocked2:
    (gen2 rav)
    thanks po sa reply.. sige I'll check before ipaservice. newbie here.
    eto pa additional info,,
    naglagay ako ng salaan sa ilalim kung saan ko nakita after ko i park sa garage... nakita ko kinabukasan kulay red yun laman... coolant yun tumutulo...?
    anymore suggestions?? wow 38k pala bago rad... hmmm... sir di ba mag overheat pag water lang temporarily gamitin ko.. ? salamat ..
    (gen2 rav)
    pula? green ang coolant eh... baka may kalawang na kasama. if this is the case, talagang kailangang palit ka na ng radiator.
    pasakay na rin ako dito sa thread ah.
    yung oto ko kasi, every week naglalagay ako ng coolant or water sa reservoir. wala namang tagas, hindi naman nag-ooverheat. medyo mabilis lang maubos yung fluid sa reservoir. saan kaya problem nun? i've checked the hoses too, wala namang tulo.
    sa radiator cap kaya ito?
    Sep 2004
    AFAIK, yung Toyota Extended Life Coolant, pula yung kulay ng coolant, so there may be brands na kulay red na rin. But I like the traditional neon green though. Parang radioactive kasi ang dating, hehehe
    * 1D4LV, unahin mo na palitan yun radiator cap...mura lang naman then go from there...
    thanks bro... i'll just get a cap this weekend and observe.
    Aug 2006
    Do not use regular tap water kasi dito sa pinas ang tap water natin ay masyado marami impurities that accelerates coorrosion of metal it is good to use distilled water ung nasa bote like absolute kahit hindi ka na mag coolant di ka agad kakalawangin. In addition puede rin siya sa battery
    Re: Red Coolant
    For the Rav4, kulay red yung coolant. I think iba yung ingredients nito from the green one. Never mix the two.
    Pa-check mo na lang yung cooling system mo. Pwede kasi sa hose & water pump din manggaling yung tulo.
    Re: New Radiator
    Yung 38K yung sa Toyota na radiator. Alam ko yung sa Evercool nasa 10K lang.
    Re: Distilled Water
    +1 on that. Pati yung sa washer fluid ko naka distilled din ako para safe (got that tip from niky)
    Jan 2008
    nagka ganyang problema din ako sa auto ko....yung akin nman every week nauubos ung kalagay sa reservoir ng radiator ko...then napansin ko may konting leak pala sa radiator....then dinala ko sa servitek...yun may butas nga radiator ko....so pinalinis and pinaayos ko na ung radiator ko....and it cost me 2250...sa ngayon ok na sya...
    Nov 2003
    why not have the leak pinpointed and have it fixed? it seems like the ideal solution.
    Guys up ko lang...
    Nagpalit na ako ng Radiator
    pero nauubos parin!!!
    san kaya ang may tama nito???
    ganito sya nauubos.. hanggang mag settle down na ang engine heat,, then kinabukasan,, dun ko napapansin pag gising ko ng umaaga ay bawas na yun coolant reservoir..
    humihigop pa ba ito mula sa reservoir kahit patay makina??
    pero during driving hindi ito nababawasan...
    help po mga sirs..
    help po mga sirs..
    you've got a leak somewhere. check the hoses and the underside of your car kung san nangagaling yung leaks.
    Apr 2009
    surely may leak yan, yung nga lang have to look for it, minsan kasi sa hose sobrang liit ng tulo na d mo makikita. ideally kasi bago pa rad mo d yan dapat nagbabawas kahit 1month pa. ok pa ba yung aux fan mo? gumagana ba pareho?
Coolant Tank, leaking... need help
