Page 1 of 4 1234 LastLast
Results 1 to 10 of 38
    Aug 2007
    1. Mga Peeps Ask Ko Lang What Brand Ng Coolant ang the Best Yet Affordable?
    2. Pati Ba Sa Water Reservior, Coolant Din Ang Ilalagay?
    Oo nga, sa Mazda3 ko kasi wala ako nakita na lalagyan ng water for the radiator. Sa coolant na lang ba?
    Quote Originally Posted by chr1smj_15 View Post
    1. any coolants are ok. ako, i personally use Shell.
    2. yes, pero mixture din 1:1 ratio din.
    Jun 2006
    Any coolant will do just stay away from the Dexron type coolant.
    Aug 2007
    tnx mga papies for the advice.
    ok din yung prestone... sama mo na si gaby dela merced...
    I just buy from the casa, pre mixed na so no need to mix water, ratio etc...buhos na lang
    Prestone 1:1 ratio with absolute distilled water including reservoir. * P230/li or P600/gal. nga pala claim ko yung prizes ko from prestone this fri. sa transhow - nang makapag pa-picture kay gaby dela merced :bwahaha:ayos na ayos ngayong tag-init.
    Jan 2008
    I use Top1 coolant sa isa kong car at 100 petot per can. I use only 1 can but change my coolant every 6 mos.
    A 50/50 coolant mixture will only have 50% heat removal compared to 100% pure water. With less 'coolant in the mix' you have more heat removal capacity but for corrosion protection and lubricating properties a more diluted mixture needs to be replaced more often, which I am willing to do.
    Radiator cap pressure rating should also be within your car specs or higher for increased boiling point, also to prevent hot spot formation, and pump cavitation.
    I also use Shell and Caltex long life at 25% mix sa iba kong sasakyan. Wilkins (or kung ano mura na foodgrade distilled water) ang pinaka tubig ko.
    I use dex-cool extended life 5yr coolant.... pero any coolant will do.
Coolant...
