Results 21 to 30 of 38
- Jan 2008
- 380
April 21st, 2008 05:35 PM #21Stovetop experiments do not mimic the 'closed cooling system of a car (open only when radiator cap capacity is exceeded'.
That is why the car cooling sytem is not as good w/o a radiator cap.
Running a pure water with a cap rating of 0.9 (0.9 x 1 Bar or 14.7 PSI} will increase its boiling point to 115 degrees C. The boiling point of water increases 3 degree F per PSI, a 25% coolant mix will further improve this with other benefits.
Adding a surfactant like 'Redline's water wetter' will improve further your cooling sytem.
You can read this link to give you another view (although there are a lot of this kind in the web really).
http://www.turbomagazine.com/feature...t_results.html
I would say that the readers should read more on this subject before giving a final conclusion.
Tsikot Member Rank 4
- Jun 2006
- 2,605
April 21st, 2008 09:08 PM #22
- Jan 2008
- 380
April 22nd, 2008 09:33 AM #23CORRECTION PLS:
The boiling point of pure water increases to about 250F or 120C using a 0.9 radiator cap. I posted erronneously by using 10 PSI radiator cap pressure. A 0.9 radiator cap will exert 13 PSI pressure on the cooling system.
Most vehicles today operate at a rather higher normal operating temperature range from about 195F(90C) to 220F(100C), older vehicles have lower normal operating temperature. A higher than the normal range is an invitation for a toasted engine because its metal temp is much higher than the coolant temp.
A 50/50 mix will have a boilover at 265(129C) but most conventional engines are not designed to run with a coolant temp at this level, anything goes beyond 220F(100C) is bettter dissipated immediately by an efficient cooling system.
Here is a link to official Redline water wetter primer. It contain some basic info about cooling system as well.
http://www.redlineoil.com/whitePaper/17.pdf
I am not an advocate either of 'Only Pure Water'. As science progresses a better engine and a better 'coolant' will be discovered.
What I have presented are just options for economizing the cooling system maintenance in response to the original post, no hard and fast rules intended.
- Jan 2008
- 380
April 22nd, 2008 10:02 AM #24BTW, sir userfriendly magkano po ba Redline Water Wetter for a 6 liter cooling system.
How can you test the effectivity of red line water wetter? I mean, your t-stat should keep the temp pretty constant, right?
Yung sa car ko just a little above the beginning of the green mark with aircon on, combined city and highway driving at 50:50 coolant mix. W/O aircon the pointer will rise just a little above the midpoint of the indicator before the high speed fan turns on.
April 22nd, 2008 03:33 PM #25
nice nice... I am also an advocate of deionized distilled water... the kind you have in dextrose bottles but of course it is too expensive... made some research with water wetter and they say it's smelly.
- Jun 2006
- 2,605
April 22nd, 2008 05:41 PM #26
April 22nd, 2008 06:35 PM #27
[SIZE=-1]Summary of Results. Water does not cool best. But water with a surfactant is an excellent coolant. Pure ethylene glycol gives the best boilover protection, but should never be used in non aqueous solutions because it's inflammable. Given that most drivers are concerned with freeze protection as well as cooling, a 50/50 mix, plus a surfactant is the best choice.[/SIZE]
I don't know about you guys but reading these graphs from the link Niky posted confirms my previous knowledge that 50/50 mixture plus Redline Water Wetter works best for all around use. I wanted to try a pure water + Redline Water Wetter but I sometimes drive in places that get really cold here so I opted to use the 50% mixture combined with the surfactant.
My car's temperature has always been consistent. Now, with newer cars sporting less gauges and more indicators alone, it's even harder to tell if the temperatures rose by just a bit because all you get is a "too hot" light once it's getting hotter than usual. By how much, we don't know.
- Jan 2008
- 380
- Jan 2008
- 380
April 23rd, 2008 10:37 AM #29I don't know about you guys but reading these graphs...
1. higher heat capacity - volume per volume H2o hold a lot more heat. A smaller capacity cooling sytem with pure water can absorb more heat faster..
2. And_ it has also higher thermal conductivity - Pure water gives up more heat with lesser temperature gradient. In a relatively cooler radiator environment pure water will release more heat faster.
3. Plus_ Pure water has lower viscosity - it will move faster in the cooling system.
....SO PURE WATER HAS A HIGHER HEAT TRANSFER ABILITY....
But is pure water the best coolant for engines, lets take the major CONS:
1. Pure water has a lower freezing point(0C or 32F) - Freezing is not a problem in the Philippines.
2. Pure water has a lower boiling point(100C or 212F). - Most cars today has a normal operating range between 195F to 212F with the Thermovalve fully opening at around 195F. Using a radiator cap with at least 0.9 rating (that is 0.9 x 1 bar or about 14.7 PSI) will raise the boiling point of pure water to 250F or 120C.
There is 3F increase in boiling pt. per one PSI pressure applied. Mixing it with 'coolants also raises its BP. But as said, you really don't want your coolant temperature go beyond 212F coz' the engine metal temperature is much higher than the coolant temperature. The risk for a TOASTED ENGINE is looming.
3. Pure water has a higher surface tension - this translates to a lesser percent coverage per surface area of the cooling system. Redline's water wetter and other SURFACTANTS claim to solve this.
4. With Pure water corrosion is high. Ethylene glycol in pure form is also highly corrosive.
Redline has enlightening technical info and figures, it is good to read their primer on their water wetter product.
Anti-freeze, anti-boil, and anti-corossion properties need not be sourced solely from Glycol products, they can be bought separatety according to your needs and fancies.
The older vehicles operate in a lower operating range, but with the attempt to produce more power per engine displacement, very high fuel economy, and very strict emmision control the results are the high heat producing engines in our time. Diesel engine manufacturers in the US, as diesel are gaining popularity, are predicting a 30% hotter diesel engines in order to comply with the government's regulations on pollution control.
Solution, 50/50 glycol coolant mix?....................
April 23rd, 2008 11:45 AM #30
I'm not arguing with you, my reply was an insight to my driving conditions here in the US where it gets cold as well. Although it's not anywhere near freezing, I'd like to have the peace of mind that my car can sustain driving in those conditions if needed be. This is the same when I go to the desert, I'd like to know it'll handle the extreme heat and cold. Have you ever been to the desert at night? It gets really cold, but come morning the temperatures soar. Those extremes place an increased demand on the system. Back there maybe not so much as the temps remain consistent around the mid-30's, but here it's entirely different.
In that stovetop experiment, I'm sure with a properly closed system the radiator cap would still increase the boiling point much further. There was a reason that 50/50 anti-freeze and water is the recommended cooling fluid for our system, and that is to get the best of both properties.
To each his own.
