Results 1 to 4 of 4
- Sep 2010
- 131
October 1st, 2011 05:09 PM #1I plan to replace my compressor for my Toyota Corolla 95 XE, can anyone suggest a brand/model that will be compatible for my car? most shops i went to suggested Denso, others suggest a smaller one used for taxis and some say i get the bigger one. Smaller one cost around 4500 and the bigger one is around 8000. They told me to convert it instead of replacing surplus or the same type(original) because surplus have no guaranty on how long it will be good and the old original one might be phased out eventually because its more than 10 years old even if its brand new, and its very expensive. they all suggested to replace the drier and to clean a part in the evaporator to make it cool again. Any suggestion on what i should buy?
October 1st, 2011 07:17 PM #2
Sanden TRS compressor ang orig na compressor niyan XE 10K nalang ngayon yan.
puwede rin i convert sa SD-5 model na sanden 507 134a. 4K ang China, 8K ang orig. singapore.
Drier 400pesos, evaporator pa check mo baka local, palitan mo ng orig serpentine 2K Lang yon.
condenser baka marami ng piyaot palitan mo na rin 1K lang yon, mura lang parts niyan nag papamahal lang diyan yun gagawa.
- Apr 2019
- 1
April 15th, 2019 12:00 AM #3Need ko palitan compressor for corolla xe 94, sabi ng mekaniko ko cannot use the
R134/R15A na nabili ko sa part in galing altis original dense ? Ang sabj naman ng nabilhan ko all cars with 2e engine iisa lng ang ginagamit na compressor which is R134/R15A, medyo na confius po ako. Pls help.
- Nov 2012
- 84
April 16th, 2019 11:12 PM #4I would suggest go to ac specialist muna para makakuha ko info. Frigid zone medyo parang casa type.
Then balik ka sa mekaniko m para siya na gumawa
Sent from my LDN-LX2 using Tapatalk
It should be repairable. The labels on the tire sealant all say that its a temporary fix and you...
Liquid tire sealant
