Results 1 to 10 of 14
- Nov 2007
- 13
November 15th, 2007 04:57 PM #1Hi Guys, Im quite new here yet I have tons of problems regardinig my ride.
First problem is my aircon compressor. I just want to know if the aircon compressor of SR20 engine compatible with the aircon compressor of nissan cefiro 97 model? I replaced the compressor of my nissan cefiro with the above mentioned compressor(with a little alteration on the high and low pressure tubes) and im not quite sure if the engine can take the load of the new compressor or if it will interfere with the computerbox. I also here (makinilya) noises as I speed up or accelerate does the compressor has anything to do with the tyope sound of my engine?
Pls advise thanks.
November 15th, 2007 05:35 PM #2
- Nov 2007
- 13
November 15th, 2007 05:52 PM #3Havent tried using a high octane rating gasoline since I bought the car 3weeks ago. How about the fuel air mixture? how to check on that?
November 16th, 2007 08:18 AM #4
November 16th, 2007 12:14 PM #5
Doesn't the Cefiro require 95 Octane? I remember that quite a few Nissans from that time did.
November 16th, 2007 12:42 PM #6
Yes the Cefiro requires 95, if you want to make sure teh AF is right, just bring it to your nearest casa for a tune-up and it's included with the service (they'll be using the CONSULT II tool).
As for the compressor, not really sure as the Cefiro uses a computer-based AC system, right?
- Nov 2007
- 13
November 16th, 2007 04:36 PM #7I will be goin to speedlab tomorrow for tune up and check-up. I will update you guys after tomorrow
November 16th, 2007 05:59 PM #8
Check the following:
- timing (although it should be set already as the timing of the Cefiro is done through the computer)
- fuel; The cefiro requires 95 octane. Petron XCS is okay.
- knock sensor
- Nov 2007
- 13
Tsikot Member Rank 5
- Nov 2003
- 3,848
November 18th, 2007 10:25 AM #10the sound from the engine is knock. you have to use blaze or velocity on the cefiro.
Agree on the consistent implementation of traffic rules and regulations. By privatizing MMDA,...
SC (temporarily) stops NCAP
