Results 1 to 10 of 12
- Mar 2007
- 26
May 25th, 2009 10:48 AM #1pede b iwelding ang condenser?nung nilubog cia sa tubig may maliliit n leak cia sa gitna.isang helera.
May 25th, 2009 11:09 AM #2
dipenda s location ng leak kasi pagtago mahihirapan na rin, sa ceejay nagpagawa ako nakitaan ng leak kaya lang sa ibabaw kaya wala pang 3 mins tapos na ang welding.
- Mar 2007
- 26
May 25th, 2009 11:23 AM #3ung helera sa may ibabaw.kaso d lng sure kung sa loob o d2 lng labas.nung nilubog ung isang corner may 3 to 4 leaks n agad.d p nalubog buo condenser nyan.
THE AUTO SPECIALIST
- Mar 2006
- 607
May 25th, 2009 06:22 PM #5
I agree with bambino, change the condenser to a new one, it's hard to have an aircon malfunction again in the middle of a very hot day with heavy traffic to boot.
- 34
October 14th, 2009 10:45 PM #6
- Jan 2011
- 1
January 20th, 2011 10:47 AM #7pwede ba i repair ang condenser ng air con kc may nag sabi saken aluminum daw yun at d pwede i repair..
January 20th, 2011 11:18 AM #8
if the condenser is found leaking, kailangan na talagang palitan ang condenser.
"stop leak" compounds are not recommended, as they are a temporary solution and can damage A/C components, resulting in expensive repairs.
January 21st, 2011 07:44 PM #10
puwedeng i repair yan aluminum welding, pero minsan pag my aluminum corrosion na pag nainitan siya dumarami ang butas, 1k lang yan pag universal na condenser depende lang sa size, pag laminated type sa mga modelong sasakyan mga 5k...
Dati kasi, Sojitz Corp ang distributor ng Geely locally, ngayon Geely Motor Philippines Corp....
BYD Philippines
