Results 1 to 20 of 35
    greetings. after having high speed overheat, i decided to flush my rad then refilled it wit coolant mix but i noticed small bubbles until it overflow (like soap bubbles. could it be a HG turned bad, or something else?
    if it is really a HG problem, any shop yu could recommend and how much do yu think i need to prepare? my car is an old accord 95 exi a/t.... many thanks in advance, regards to all...
    btw, for reference, mine is overflowing with tiny/small bubblesjust like in this video ..http://www.youtube.com/user/mickbmx#p/u/7/Lk9-JhHzAKQ
    Feb 2005
    Sir nagoverheat na po ba ito? baka may deperensya na yong cyl head gasket.
    Kung malapit kayo sa location namin, Try niyo po pumunta sa shop namin bukas.
    [size=14pt]JOPREMAR ENTERPRISES[/size]
    Fermin Aircon, Electrical and Radiator Shop
    Address: 1291-A Quirino Ave, San Dionisio, Paranaque City
    Tel: (02) 829-3771 / 775-2293 Text: 0915-5413610
    email to: jovi1645*hotmail.com
    http://sulit.com.ph/1522292
    Jan 2010
    peztie sir ano po nangyari na sa car niu? ganyan din kasi yung car ko pero di naman nagooverheat. it runs normally naman.
    Jul 2010
    Quote Originally Posted by dest View Post
    sir meron kaung pang lancer 97 na radiator fan? magkano po?
    Feb 2005
    Quote Originally Posted by B.AGIMAT View Post
    Sir nasa PM website ang reply ko sa inyo
    hey guys, just want to update you on how I solved my accord's problem and how much it costs me
    guess what, the actual cost of the solution is less than 400 bucks and the culprit? radiator lower hose, .
    but here is the catch...
    I was really convinced that my problem was an HG issue so I decided to order compression and leakdown testers from US, and other different testers, scanners and tools to maximize the items i can place inside the box, preparatory to my plan of having my car top overhauled.
    but since my other cars were not available yesterday, thanks to MMDA color coding, i took the courage to use my accord going to manila after i replaced the hose by a replacement one i bought from fertes months ago. although hesitant at first to drive too fast, i noticed however that nothing was unusual in my temp gauge so I decided to speed it up purposely to check if it will overheat just like before. luckily, it did not.
    To cut the story short, i solved my long overdue problem for a measly Php400 but i have now a bunch of testers/scanners and mechanic's tools amounting to a new engine that i have no other option but to pay
    the lesson i learned, bubbles and highspeed overheat does not necessarily mean an HG problem or blown CH and, the moral of the story, dont presume the worst unless all the petty things have been checked and done already...
    BTW, many thanks speed unlimited, sleepsus for your ideas and suggestions... and regards to all.
    phezthie
    May 2009
    Quote Originally Posted by phezthie View Post
    the reason why it's the lower rad hose is because due to its old age and it is collapsing at high speeds creating vacuum in the water jacket in the engine block....i did recommend checking the lower rad hose at the other "overheating thread" in this forum. i don't know kung ano na ang nangyari.
    the bubbling issue happened to me... i changed first the lower rad hose. no good until i decided to change the HG. no bubbles so far.
    May 2010
    Hi Sir,
    Normally when the HG will go bad, you have to replace it with an OEM instead of bringing it to the machine shop for re surfacing. I have a mitsu lancer & the OEM HG costs 1, 700 PHP at shaw merchandising. Yours is honda so i suggest you check with supplier.ph the price of an original HG.
    BTW, check you oil cap if you will notice a mix of oil & coolant. If YES, the HG or the CH might be in bad shape already. Also, white smoke in the tail pipe with water or coolant indication shows that the coolant is already flowing in the combustion chamber.
    Try speedyfix. Sir Migs is the best judge for that cases. He can give you a rough estimate for your case.
    Quote Originally Posted by kidlatfernandez View Post
    Hi Sir,
    sir negative po white smoke, oil & coolant mix sa tingin ko wala din. ginamit ko uli ngayon, nag overheat sa higheay pero sa slow driving ok lang temp ng oto...
    san sir location ng speedyfix? any contact numbers? ty in advance
    Gumagana ba iyong auxillary fan mo. Subukan mo buksan sa umaga iyong hindi pa mainit makina mo ang radiator cap . Pa start mo sa kasama mo makina tignan mo kung bumubulwak o lumalabas ang tubig sa bibig ng radiator kung lumalabas head gasket iyan . Tignan mo rin iyong thermostat.
    Quote Originally Posted by speed unlimited View Post
    * speed_unlimited: sir ok yung 2 fans, gumagana din yung thermo switch. wit regard sa pag start kung me tubig bubulwak, negative din sir.....
    update ko na din mga sirs, nawala na yung mga bubbles probabaly because ni re-torque ko yung head as advised in other threads. but the problem is still there, overheat pa din pag long driving, pag traffic wala problem...any ideas mga gurus....TIA
    Kadalasan iyong madalas mangyari pag traffic nag ooverheat dahil nakahinto at hindi nakakasagap ng hangin baliktad iyong sa iyo . Ang mga cause ng overheat check mo na lang Radiator maaring barado , Sirang radiator cap, radiator hose may leak . Nagbabawas ba ng tubig check mo kung may leak sa mga clamp ng hose. Sa tingin ko sa video barado iyong radiator mo pa check mo muna sa gumagawa ng radiator. Ganoon muna gawin mo at sabihin mo sa amin resulta.
    double post, sori
    Aug 2003
    you'll find a map on their site - http://www.speedyfixph.com/
small bubbles in radiator, busted HG?
