Results 1 to 20 of 24
    kaninang umaga, napansin ko na paglagay ko ng coolant/water sa reservoir ko, ang lakas ng tagas sa ilalim. i assume may butas.
    questions:
    a. may mga replacement parts ba na reservoir na pwedeng gamitin? car is lancer 2k. mga magkano ang price nya? saan nakakabili?
    b. kung oem lang, magkano din yung cost?
    thanks.
    bro, mabilis lang alisin yan, so tingnan mo muna at parang mahirap mabutas yan dahil made of hard plastic yan and kung coolant/water lang nilalagay di mabubutas ng basta-basta...baka yun hose ng papuntang radiator ang sira or yun clamp niya?
    thanks bro. i'll take your advise first.. i'll check this weekend.
    you can check it tonight or sa lunch break...hehehhe it won;t take you 5 minutes to remove, check and return the reservoir...hehehe
    Dec 2007
    Quote Originally Posted by 1D4LV View Post
    questions:
    thanks.
    Sa mga surplus shops yata, meron. I bought my replacement windshield washer tank and motor from one several years ago. Mura lang. Kung meron silang ganun, meron din siguro silang coolant reservoir.
    Good luck finding one!
    Nov 2007
    questions:
    thanks.
    common problem ng water reservoir sa katagalan ay cracks due to it is made of plastic and plastic when used for longer period of time it will become brittle. Gamitan mo nalang ng PIONEER EPOXY for plastic application 2 types kasi ang epoxy for steel and plastic, choose the plastic one.
    tatagal din ang epoxy kasi ginamit ko na yan sa water reservoir and up to now okay pa. about 2yrs na yun.
    Quote Originally Posted by Esnie.com View Post
    thanks bro... nice idea...
    i
    May 2007
    i
    Oh no! Its good but not that good, what your doing it's just a quick fix. Like he said (1DL4V) that plastic reservoir became brittle in time and putting an epoxy is not a good idea since the life span of that plastic are now up to the integrity limit. Change it to a new one before it give's you more headache.
    Nov 2003
    better to bring the sample when looking for the part para sure ka tama lahat ng sabitan and brackets and wala ka na ireremedyo.
    Sep 2005
    medyo OT question pero re:coolant reservior. every 2 days of using the car then check yung tank, ubos yung water. ano po kaya problem nito? yung coolant naman sa radiator di naman nabawasa...sigh.
Coolant Reservoir
