Results 1 to 20 of 24
    May 2007
    Quote Originally Posted by 1D4LV View Post
    thanks bro... nice idea...
    i
    Oh no! Its good but not that good, what your doing it's just a quick fix. Like he said (1DL4V) that plastic reservoir became brittle in time and putting an epoxy is not a good idea since the life span of that plastic are now up to the integrity limit. Change it to a new one before it give's you more headache.
    Nov 2003
    better to bring the sample when looking for the part para sure ka tama lahat ng sabitan and brackets and wala ka na ireremedyo.
    Sep 2005
    medyo OT question pero re:coolant reservior. every 2 days of using the car then check yung tank, ubos yung water. ano po kaya problem nito? yung coolant naman sa radiator di naman nabawasa...sigh.
    ^^ sir check niyo po yung hoses and kung may maspotan na leak. nagpadrain na ba kayo ng radiator?
    baka maluwag ang lang clamp? di kaya?
    Sep 2005
    *archie and s_quilicot: thanks sa reply. wala naman leak sa mga hoses and yes na drain ko na radiator then lagay bago coolant. yung clamp oks naman lahat.
    Quote Originally Posted by puroy View Post
    bro check your radiator cap muna. baka loose lang and kailangan lang palitan. mura lang yun.
    Dec 2007
    +1 sa radiator cap. Na-experience ko na yan, e.
    Quote Originally Posted by woohoo View Post
    Agree that the radiator cap is one of the most probable causes.... Check if the rubber lining in the cap is still intact. If it is not, then there is your source of leakage at high pressure....
    6110:pepsi:
    Nov 2003
    yup, replace the cap. simple and cheap test.
Coolant Reservoir
