Results 11 to 20 of 20
- Jul 2005
- 122
August 22nd, 2005 08:12 PM #11bro, thats exactly my current problem... this weekend lang nagloko aircon ko. when i start the engine & aircon, minsan wala akong naririnig na click na nag-indicate na on na ang a/c, parang fan lang & after some time while driving, gradually lumalamig na but not as cool as before... what should i tell the repair guys pag nagpunta ako sa shop? thanks.
Originally Posted by astorath
August 22nd, 2005 08:26 PM #12
pag ganun chinecheck usually fuse at mga wires going to the compressor. Paminsan naman yung thermostat switch ang sira.
August 22nd, 2005 11:50 PM #13
[I]humming sound sa hood? bka ur compressor needs replacement na worn bearing n un mlamang at kung erratic ung paglamig worn clutch plate na kya minsan nka engage or vise versa. check m rin thermostat ng aircon ang gli prone sa pagloloko pag luma na. dont try to overhaul the cmpressor magttpon k lng, buy new or surplus na my warranty pra safe ka. check also kung tama idling loko2 ung mga ngdsign ng mdel n yn evrytme nag drop ng blow 6- 700rpm ng sshotoff ang cmpressor pra daw dka mmtayan, ang tnong e bkit m nman ibaba? mgttipid k gas? hehe
- Jul 2005
- 122
August 23rd, 2005 07:27 PM #142 weeks ago lang ako nagpalinis ng aircon, replace filter/dryer & check valve... but when i brought my car to the shop in boni for a tune up, dun na nagsimulang magloko aircon. i dont know kung yun ang cause, during tune-up nilipat ng mekaniko ang hose from the carburetor sa isang vacant tube na nasa carburetor din bec di na daw gumagana ang tube na yun and tumaas ang idling. before the tune up ok naman ang aircon or talagang timing lang na nagloko ang aircon ko regardless kung ginalaw ang carburetor ko o hindi... by the way, my ride is ae92 1.6. and my problem is similar to astorath. Thanks guys.
May 14th, 2007 09:07 PM #15
from my experience and from what I know from the threads usually pag nagpalinis doon nasisira..
Kaya wag na lang palinis hanggat masira na lang. Yung honda hatch ko before never ko pinalinis (4 years).. binenta ko maayos pa.
May 16th, 2007 04:50 PM #16
yung bubbles sa sight glass is not applicable diagnosis sa r134-a system, para sa r12 system lang yung diagnosis na pag me bubbles ay low charge kaya yung mga 134a system karamihan ng receiver drier ay wala ng sight glass. for info lang ho.
- May 2005
- 20
May 17th, 2007 09:21 AM #17pasakay naman sa thread.
problem ng aircon ko is, bigla na lang nawawala yung lamig (blower na lang). specially if maiinit sa labas. then after a while babalik din yung lamig.
pag hindi naman maiinit, like early morning and at night, ok naman yung lamig nya.
ano po kaya problem ng AC ko?
May 17th, 2007 04:48 PM #18
- May 2005
- 20
May 18th, 2007 11:28 AM #20
on mo ang aircon then check yung fan kung gumagana, minsan kasi hindi gumagana or intermittent ang operation nito kaya intermittent din ang lamig ng aircon, dapat every time magon ang aircon(engage ang compresor) andar din ang aux fan ng aircon at pagmalamig na compressor will disengage ang auxfan mamamatay din, pag hindi gumagana ang fan check connection or replacement na ng aux fan, ganito ang nagyari sa akin palit nalang ako ng bagong aux fan kila mang mario 2500pesos ang bill ko.
I have those "Fire Stop" brand extinguishers by the driver's door cup holder/pocket. I don't think...
Fire Extinguisher for Car: what brand and type...
