Results 1 to 7 of 7
    ako po ay may problema, my ride is lancer 90 model, horn is ok if a/c is off, but when i turn it on, busina fails. tech info about this and what should i do. tenk po
    you have a dead alternator at mababa na charge ng battery kaya pag on ng a/c ay bumababa din ang voltage. pag on ng a/c mo masyado malaki power drain so dun napupunta lahat ng natitira pang power sa battery.
    have it checked right away, ititirik ka nyan sa gitna ng kalsada pare. pag naubos charge ng battery mo pati na spark plugs mo wala na ding koryente at dead in the middle of the road ka. isa pa, pag totally discharged ang battery baka masira ang plates so dagdag gastos yan.
    thanks for the reply sir. Well the problem is going on for quite sometime, to add to the troubleshooting eh kaka pa tune up ko pa lang last week, and i think that includes checking the battery. Well i guess sana its only wire problems lang, anymore advice about it
    Mar 2003
    edzz,
    i also had the exact experience din before... i checked my whole busina system pati na rin yung air-con, pina-tingnan ko din alternator tsaka battery....
    and then nakit nung technician na busted relay ng busina ang diperensya...
    check mo na din relay mo baka kailangan na din palitan...
    share lang baka makatulong...
    tenk you po, patignan ko nalang relay.
    ground lang katapat nyan...........
    yup,, kung di sira ang relay mo baka kulang sa grounding yung oto mo.
busina while a/c is on
