Results 1 to 10 of 10
    Dec 2009
    Mga pre, kelangan ko ng konting kaalaman senyo. Nag-overheat kasi minsan ung auto ko then dinala ko sa isang shop. So pina-overhauled ko na sa kanila ung makina as well as ung radiator ko. But then napansin ko na napupuno masyado ng coolant ang reservoir ko. I tried to open the radiator at mukhang ok naman naman dahil nagci-circulate naman ng maayos ang tubig sa radiator. Pero nung sinubukan kong i-rev, biglang bumulwak ang tubig sa radiator na parang bumubula. Tanong ko lang mga pre, normal lang ba ito?
    Feb 2005
    Quote Originally Posted by RedAxel View Post
    Hindi normal yan sir, Baka di nakita na may cracked yong cylinder head. Tanungin mo sa mekaniko kung nacheck nila yong cylinder head.
    Dec 2009
    Thanks sir sa advice. Pero me nakita ako isang turnilyo sa gitna na parang na losethread na. Posible kaya ito ang dahilan nun? Ano ang remedyo dito?
    Please check your radiator hoses. Both or 1 pc of the radiator hoses might be defective, nagvavacuum.
    Dec 2009
    Salamat sa mga replies nyo sir.
    Oct 2007
    Binalik ba thermostat after the overhaul?
    It could also be something as simple as an air pocket in your cooling system which may not have been bled after a coolant drain and fill.
    to clear your mind dapat ibalik mo muna sa gumawa, that condition is not normal it's similar to a blown head gasket failure. or baka may warp ang head and hindi na resurface or the head is not properly torqued to specs.
    Dec 2009
    Pina-check ko sa ibang mechanic, and yung tingin nya is head gasket pa rin ang sira.
    Feb 2009
    car manufacture year, model, year, engine? if one or more capscrew on the cylinder head is not clamping properly, it will lead to a warped or bent cylinder head if not bent yet. this engine might be using torque to yield (plastic region bolts) and they are not designed to be reused, everytime you remove the head, it is mandatory to replace all the capscrews. if the head has cracks, take it to a machine shop for magnaflux or other ways of crack detection.
    jick
Bumubulwak na tubig sa radiator pag rev
