Results 1 to 10 of 10
December 16th, 2009 02:08 PM #1
Mga pre, kelangan ko ng konting kaalaman senyo. Nag-overheat kasi minsan ung auto ko then dinala ko sa isang shop. So pina-overhauled ko na sa kanila ung makina as well as ung radiator ko. But then napansin ko na napupuno masyado ng coolant ang reservoir ko. I tried to open the radiator at mukhang ok naman naman dahil nagci-circulate naman ng maayos ang tubig sa radiator. Pero nung sinubukan kong i-rev, biglang bumulwak ang tubig sa radiator na parang bumubula. Tanong ko lang mga pre, normal lang ba ito?
December 16th, 2009 07:08 PM #2
December 17th, 2009 11:24 AM #3
Thanks sir sa advice. Pero me nakita ako isang turnilyo sa gitna na parang na losethread na. Posible kaya ito ang dahilan nun? Ano ang remedyo dito?
- Nov 2009
- 87
December 22nd, 2009 07:35 AM #4
December 31st, 2009 08:29 PM #6
December 31st, 2009 10:22 PM #7
It could also be something as simple as an air pocket in your cooling system which may not have been bled after a coolant drain and fill.
January 1st, 2010 12:14 AM #8
to clear your mind dapat ibalik mo muna sa gumawa, that condition is not normal it's similar to a blown head gasket failure. or baka may warp ang head and hindi na resurface or the head is not properly torqued to specs.
January 3rd, 2010 02:07 PM #9
Pina-check ko sa ibang mechanic, and yung tingin nya is head gasket pa rin ang sira.
January 3rd, 2010 08:58 PM #10
car manufacture year, model, year, engine? if one or more capscrew on the cylinder head is not clamping properly, it will lead to a warped or bent cylinder head if not bent yet. this engine might be using torque to yield (plastic region bolts) and they are not designed to be reused, everytime you remove the head, it is mandatory to replace all the capscrews. if the head has cracks, take it to a machine shop for magnaflux or other ways of crack detection.
jick
