Page 1 of 3 123 LastLast
Results 1 to 10 of 22
    Aug 2005
    Gud am mga tsikoters, I have my problem with my original radiator plastic/fiber glass radiator kasi may rust sa inside tapos di pa nman mag overheat kasi coolant gamit ko and battery water na purified gamit ko tapos nag flush na din ako..
    palitan kuna po ba or palitan ko ng brandnew or surplus magakano po ba? tips lng po.. ty ha!
    Jun 2005
    Brand new about P16,000. Surplus mga P3,500. No labor yet. I think your radiator is still OK.
    Aug 2005
    Quote Originally Posted by j_avonni
    meron daw 5k * metal na daw lahat.. ang sakit ng 16k subra mahal.. surplus nlang me.. ty po!
    Aug 2005
    teka sa-an yong thermostat?
    baka stucked yung thermostat mo, try to check it.
    dont change it to a metal top, kung magoverheat ka cylinder head agad ang masisira.
    DENSO repairs the radiator tops, if di kaya, mag surplus ka nalang, or di padin, just get an evercool radiator.
    Aug 2005
    Quote Originally Posted by theveed
    wow.. pre.. galing mo talaga.. number 1. thank you ha. di pala maganda yong metal top radiator at mabuti pa din tong sakin kaya nga lang sabi kasi ng mechanic di daw pwde ma clean up ang rust kasi orig daw at baka masira.. maintain ko nlang cguro to at parati kung lng pa flush kasi okey pa din eh wlang bara..
    ano po ba other maintenance para ma maintain ko muna tong rusted radiator?
    "thermostat" ano po yan kuya?
    salamat sa reply!
    Im from cebu pala. sory di ko nasabi.
    Oct 2004
    the_veed, i just had my plastic radiartor top changed to "tanso" or copper. masama ba yun? i was told that some metal tops do not adhere to the body of the radiator pero yung nabili ko seems to be okay. P1,500 or P1,800 yata just for the top kasama na installation, of course. pinatanggal ko na rin yung thermostat. super baba na ng temp ngayon.
    Dec 2004
    Quote Originally Posted by jayelgee
    Have your thermostat put back in, it's there for a reason!
    Watercooled engines are designed to run at around a certain temperature range for minimal wear and efficient operation. It's not supposed to have temps that are "super baba".
    Apr 2004
    there's a good radiator repair guy in our area, tondo, he's very good in overhauling radiators even the one's with a plastic top... cost would be less than 1k.
    or you may try dallas in tomas morato and have your radiator descaled.. i tried them out just recently, they did a fairly decent job in getting my rad cleaned.. but i think it would had been more cleaner if i just opted to have it overhauled...
Plastic Radiator Corolla Xe 96' orig
