Results 21 to 30 of 43
February 20th, 2015 10:15 AM #22
Mahala ba talaga evaporator coil? Estimate kasi sakin 5-7k kumporme sa brand.
February 20th, 2015 10:45 AM #23
3 years pa lang? Parang ang aga naman masira? di na ba covered ng warranty?
Yung dati namin adventure was already 9 years old when we sold it. Aircon was cleaned every 3 years. Walang naging problem except blocked expansion valve (replaced once). Until it was sold maganda cooling ng aircon.
With regards to "welding" the evaporator, tama yung sinabi nila. It won't last kasi mag-sprung lang ng leak ulit dahil manipis na yung walls. I experieced it first hand nung pinahinang yung evaporator ng honda namin. 1 week nasa shop na ulit kasi may singaw na naman. Pinalitan din eventually yung evaporator.
February 20th, 2015 11:22 AM #24
November nag end yung warranty eh. Sayang d pa umabot. Kahit ba bago pa hindi na din recommended na hinangin? Tapos pala magka iba ba yung evaporator sa evaporator coil? Yung ibang shop kasi palit evaporator tas yung iba evaporator coil naman which mas mahal sa evaporator. Thanks!
February 20th, 2015 12:01 PM #25
Mura lang yan just ask for replacement wag orig. Which costs way more. 3500 sounds right
February 20th, 2015 01:40 PM #26
Currently at Ceejay's. Replacement evaporator lang binili ko worth 1.5k sa rotary. Yung sa Ceejay's kasi nasa 5-7k yung branded nila.
- May 2014
- 72
February 20th, 2015 02:43 PM #27
- 54,290
February 20th, 2015 05:37 PM #28the range of prices between OEM and replacement, is big. also, take note of the model design.. e.g., laminar versus serpentine (for sentra).when my sentra's evaporator sprung a leak for the first time after 9 years, i opted for replacement. the model i (my driver, actually, whom i asked to have it repaired) got, was the cheaper one (2K yata), as against the much more expensive OEM. well... i wasn't happy with the result. bitin ang lamig.., at nag-yeyelo, despite full charge. finally, i brought it back and had the evap replaced with the much more expensive (by 4-5 times) oem. that brought the cooling back to factory spec.. apparently, the replacement evap wasn't up to stuff.. mis-matched aircon component...
also, replacement evap sometimes does not fit right into the space. this was the case with my innova's front evaporator. it was cheaper by 80%, but it was wider by less than 3 mm, and it simply did not fit into the space provided.. i had no choice but to get the oem..Last edited by dr. d; February 20th, 2015 at 05:45 PM.
February 20th, 2015 06:25 PM #29
YES choose serpentine. laminar hina ng lamig.
try mo eto
ROTARY better living 7768663
try mo eto
February 20th, 2015 06:47 PM #30
Thanks sa mga nagreply. My first choice is laminar which is more expensive. Sabi nila mas maganda daw yun at mas matibay. Kaso walang stock kaya nag serpentine ako.
Yun nga ang problema sa mga replacement naka tatlong balik ako dahil hindi fit sa housing.
So far super malamig sya at first time ko lamigin ng nanginginig sa sasakyan. Feeling ko mas malamig ngayon kesa nung una kong nilabas sa casa yung sasakyan.
Sabi sakin ng Ceejay's balik daw ako after 1 week para sa follow up check up.
190,429 cars were sold in PH, as of May 2025 | TopGear PH...
Car Sales Data (2025)
