Results 21 to 40 of 43
    Dec 2009
    #21
    Quote Originally Posted by jasonub View Post
    Sa better living dona solidad meron rotary. Di ko lang alam number. Dami sila branches
    Thanks sir! Try ko daanan bukas
    Dec 2009
    #22
    Mahala ba talaga evaporator coil? Estimate kasi sakin 5-7k kumporme sa brand.
    Apr 2009
    #23
    Quote Originally Posted by radz15 View Post
    Ohh i see. Ilang years po ba bago ma consider na luma? 3 years pa lang kasi yung Adventure ko. Thanks!
    3 years pa lang? Parang ang aga naman masira? di na ba covered ng warranty?
    Yung dati namin adventure was already 9 years old when we sold it. Aircon was cleaned every 3 years. Walang naging problem except blocked expansion valve (replaced once). Until it was sold maganda cooling ng aircon.
    With regards to "welding" the evaporator, tama yung sinabi nila. It won't last kasi mag-sprung lang ng leak ulit dahil manipis na yung walls. I experieced it first hand nung pinahinang yung evaporator ng honda namin. 1 week nasa shop na ulit kasi may singaw na naman. Pinalitan din eventually yung evaporator.
    Dec 2009
    #24
    Quote Originally Posted by garfield_08 View Post
    November nag end yung warranty eh. Sayang d pa umabot. Kahit ba bago pa hindi na din recommended na hinangin? Tapos pala magka iba ba yung evaporator sa evaporator coil? Yung ibang shop kasi palit evaporator tas yung iba evaporator coil naman which mas mahal sa evaporator. Thanks!
    Mar 2005
    #25
    Mura lang yan just ask for replacement wag orig. Which costs way more. 3500 sounds right
    Dec 2009
    #26
    Currently at Ceejay's. Replacement evaporator lang binili ko worth 1.5k sa rotary. Yung sa Ceejay's kasi nasa 5-7k yung branded nila.
    #27
    Mejo Di ka na lugi sir sa 3 years Ang alam KO 4 years pataas bumigay na Ang evaporator eh... Saka pacheck mo muna kung may leak ba talaga Bago NLA palitan.
    #28
    the range of prices between OEM and replacement, is big. also, take note of the model design.. e.g., laminar versus serpentine (for sentra).when my sentra's evaporator sprung a leak for the first time after 9 years, i opted for replacement. the model i (my driver, actually, whom i asked to have it repaired) got, was the cheaper one (2K yata), as against the much more expensive OEM. well... i wasn't happy with the result. bitin ang lamig.., at nag-yeyelo, despite full charge. finally, i brought it back and had the evap replaced with the much more expensive (by 4-5 times) oem. that brought the cooling back to factory spec.. apparently, the replacement evap wasn't up to stuff.. mis-matched aircon component...
    also, replacement evap sometimes does not fit right into the space. this was the case with my innova's front evaporator. it was cheaper by 80%, but it was wider by less than 3 mm, and it simply did not fit into the space provided.. i had no choice but to get the oem..
    Mar 2005
    #29
    YES choose serpentine. laminar hina ng lamig.
    try mo eto
    ROTARY better living 7768663
    try mo eto
    Dec 2009
    #30
    Thanks sa mga nagreply. My first choice is laminar which is more expensive. Sabi nila mas maganda daw yun at mas matibay. Kaso walang stock kaya nag serpentine ako.
    Yun nga ang problema sa mga replacement naka tatlong balik ako dahil hindi fit sa housing.
    So far super malamig sya at first time ko lamigin ng nanginginig sa sasakyan. Feeling ko mas malamig ngayon kesa nung una kong nilabas sa casa yung sasakyan.
    Sabi sakin ng Ceejay's balik daw ako after 1 week para sa follow up check up.
    #31
    yung mas lumamig...
    kung minsan, mas malamig na ngayon dahil hinablot ng trabajador yung aircon filter nyo!! check it po!
    #32
    Guys may alam kayong aircon shop near fairview quezon city area? mahina lamig ng aircon ng sasakyan ko, twing tag-init tumatagas yung refrigerant. Ilang beses na sinagawa ang leak test pero di makita.
    #33
    Quote Originally Posted by JoshII View Post
    bat mo sinabing tuwing tag-init lang tumatagas yung refrigerant? dahil ba sa tag-init lang hindi lumalamig? dahil sa tag-lamig naman ay medyo malamig?
    what i think is, you have no refrigerant at all, hot or cold weather. it is just that, the aircon seems cool when the weather is cool. but actually, the aircon is not cooling at all.
    try mo sa banawe. marami diyan. my favorite is the one on the second corner to the left, coming from quezon avenue going to del monte. medyo mas mahal sa tingin ko, but mabilis and maiksi pila.
    good luck.
    good luck.
    #34
    good luck.
    Yes this is the third time it happen to me. Twice ng binaba ang evaporator at expansion valve ginawan ng leak test walang makitang butas ibinalik kinargahan ng freon then good for 12 months. this last few days pag pasok mo sa loob ng sasakyan amoy mo ang freon sa loob. Ang parking space ko sa office walang shade. I'd check also the refrigerant tubes under the hood hindi sya malamig
    Jun 2005
    #35
    ano amoy ng freon? diba dapat walang amoy yun?
    anyway, baka peke nilagay na refrigerant sayo
    #36
    Quote Originally Posted by sirkosero View Post
    Two stores na gumawa ceejay at frigid zone. Malamig siya for 12 months at hind naman nagbabago ang routine ko sa mga worked days and the same parking slot ako sa office pag pasok mo sa loob ng cabin may maamoy na masansang
    #37
    kung nawawala ang lamig, bakit hindi mo gawan ng affidavit of loss? heheheh joke.
    mukhang hindi evaporator or condenser ang problema mo.
    IMHO, AFAIK, ang problem mo eh yung condenser fan mo, mukhang mahina na na nagcacause ng high pressure sa system at eventually bumibigay ang mga component (dugtungan) ng mga air mo. in your case, sa evaporator.
    try reaplacing it with OEM surplus or brand new one, mga 1.5k to 3.5k lang naman iyun.
    by the way, anong kotse ho ba itong pinaguusapan natin. kasi iba iba characteristic ng bawat compressor ng kotse lalo na ang failsafe mechanism nito.
    #38
    Quote Originally Posted by RomeoAlpha View Post
    chevy spark sir. amoy ammonia ang loob ng car cabin ko for the past few days. palagay ko sa expansion valve uli yung leak..
    #39
    expansion valve nasa labas, tsaka kung may leak - hindi na lalamig yan.
    ung amoy ammonia, due to build up ng mold/yeast sa evap due to presence of alcohol within your cabin space.
    nakukuha ito kung matapang ka mag pabango bago sumakay ng kotse at ung alcohol content ng perfume, ay humahalo sa hangin plus condensate, ayun, yeast.
    amoy maasim na hindi mo malaman.
    simple to treat, ibukas mo airvent, ibilad mo sa araw.
    paggamit mo ulit, iblower muna, then on AC, pagpark sa bahay, antayin mawala lamig ng AC.
    two days lang tanggal yan.
    Jan 2014
    #40
    Mga sir.. Good day.. Sa akin mahina ang aircon kagabi hanggang ngaun.. Sa driver seat lang ang lumalamig at sa iba, hangin lang. May naririnig din akong parang sumisingaw sa passenger seat dashboard. Ang history daw ay may butas ang evaporator, pinawelding. Kala ko ok na. So is it time to install this new evaporator?? Paki tingin po nung image, ano po ang masasabi ninyo?
Bigla nawala yung lamig
