Results 1 to 20 of 20
    Feb 2019
    Hi everyone. Looking for recommendations for a good a/c shop in Pasig Ortigas Center, Ugong, Orambo or Kapitolyo. It's time to take my 2011 Jazz for cleaning. Bubuksan dashboard sa alam ko so looking for a shop na magaling rin magbalik hahaha!
    Salamat!
    Quote Originally Posted by e30ernest View Post
    Salamat!
    Hanapin mo yun Thread, yun sa seaoil sa Pasig magaling daw gumawa.
    IMO, If walang issue A/C mo and meron ka naman cabin filter. Hinde kailangan ipa cleaning. Hinde ma madumi evaporator mo sa loob.
    Aug 2018
    Mang Danny
    Another Aircon Repair Shop : Danknee
    Feb 2019
    Salamat!
    Actually problem ko is icing so di ko mataas thermostat ko. I wonder if the Lysol method would clear things up? Ideally ayoko sana pabukas dashboard.
    Feb 2019
    Mang Danny
    Thanks! Booked with Mang Danny this weekend. Estimate was P2500.
    Cleaning lang? Papalitan mo na rin expansion valve since ibaba na evaporator. Yun drier kahit huwag na basta hinde binuksan compressor.
    Feb 2019
    Come to think of it, di ko mashado gets reply niya hahaha! Exact text niya:
    2500 including freon plus parts
    So I'm assuming 2500 is labor + freon then plus pa parts. Is that a good deal?
    Actually second cleaning na nitong kotse na ito. Apparently vaping in the car clogs up the evaporator with sticky gunk. Last time di pinalitan ang expansion valve. Hopefully di pa palitin. That was around 5 years ago though, I cannot remember how much I paid (shop sa Bulacan).
    Papalitan mo na expansion valve. Para isang labor na lang.
    Wala ka ba cabin filter?
    Feb 2019
    Meron so I'm sure papalitan na rin yun. Car wasn't used much, but it's been pretty dusty at places I go to.
    Salamat!
    icing.
    1. low freon.
    2. un-matched aircon components.
    3. restricted air flow ("madumi").
    4. etc.
    good luck, po.
    Feb 2019
    icing.
    1. low freon.
    4. etc.
    good luck, po.
    Thanks dr. D!
    Yeah pacheck ko rin freon before we start cleaning. I'll consult with Mang Danny first. Components would be matched since this is still stock (original components from factory) so it's either low freon or barado na.
    Malamig naman siya sa start pero eventually it will ice up to the point halos walang hangin. So I am using a high fan setting (2/3) with a low thermostat (1/3-1/2) to keep it from icing up.
    Oct 2009
    madami nanaman nag po post about aircon cleaning kesyo mahina na daw.pero sa totoo lang sobrang init lang ng panahon.kaya parang mahina na ung aircon ..
    sa akin nilagyan ko lang ng aux fan sa condenser pang tulong sa init ayun solve na
    Nov 2012
    Quote Originally Posted by jaypee10 View Post
    Sobrang init nga talaga. Nilagyan din ng additional aux fan yung sakin, sa may condenser din nakalagay. Sa ngayon ayos naman. Nadaan na konsa edsa traffic ng 2 hours ayos pa naman ang lamig
    Sent from my LDN-LX2 using Tapatalk
    Ano sasakyan ninyo? Bakit kailangan mag dagdag ng fan? Kung walang issue A/C System ninto kahit anong init ng panahon, malamig pa rin yan
    what's your vehicle, po?
    sometimes, it's the condenser that's dirty.
    while adding an aux fan will help, i think the better thing to do is to clean the condenser's exterior. especially the fins and the space between the fins.
    Feb 2019
    Feb 2019
    Yun drier kahit huwag na basta hinde binuksan compressor. HostGator DreamHost Bluehost
    Aug 2019
    yea mostly it happens due to a dirty condenser, get it cleaned properly this should fix the problem
    Sep 2018
    A clean aircon can provide great ventilation to give comfort while on the road. Having the best car aircon shop will result in a better outcome as they have the best tools and skills. Due to this, I make sure that my provider is trusted and provides the best quality. I usually have a trusted car shop who handles everything related to my car. But sometimes I look for a car shop directory online. For sure they have a listing for the best car aircon shop. You might want to check it out. Hope you'll find this helpful.
    Aug 2019
    Quote Originally Posted by lovelash View Post
    9Apps Cartoon HD Vidmate
    Hey man, problem is solved or it's still there? do let me know
Best A/C Shop In Ortigas Center, Ugong, Orambo or Kapitolyo Area?
