Results 21 to 25 of 25
August 8th, 2007 09:05 AM #21
mga magkano kaya ang pa-change oil ng compressor? iba ba iyong thermostat control diode sa thermostat (kaka-replace ko lang nito kasi)
September 6th, 2007 08:46 PM #22
i have a corolla gli '93 model and i'm also having a similar problem. before i bring the car to a shop, is there some DIY checkups i can do?
in my case, the aircon usually works but there are occasions when i switch the thermostat, nothing happens. blower is fine. i'm guessing this is probably electrical and some switch or wire somewhere is loose. hope somebody can give ideas where to look, thanks!
- Dec 2007
- 2
December 21st, 2007 03:27 PM #23Can anyone give me advice, my A/C just wont work, umanadar naman ung clutch ng compressor, tapos ung tube papunta s loob ng car may condensation and mlamig sya pero ung loob ng car hot air lng ang binubuga ng fans
December 21st, 2007 03:40 PM #24
barado siguro ac line mo, wag mo muna paandarin, baka mag high pressure at masira pa components nyan...have it cleaned, probably replace drier, and expansion valve if necessary
- Sep 2007
- 110
December 21st, 2007 08:42 PM #25BAKA ANG AIRCON BELT SIR MALUWAG. YUNG SA AKIN DATI PAG MALAMIG PA ANG TEMP NG MAKINA MERONG SCREECHING SOUND NA NAKAKARINDI TALAGA PAG-ON MO NG AIRCON. PAG TANGHALI MO GAGAMITIN DI SYA UMIIYAK. USUALLY SA GABI LALO NA PAG MALAMIG PA ANG MAKINA TAPOS ON MO AIRCON DUN SYA UMIIYAK.DI MO RIN PWEDENG IPARINIG SA SHOP KASI WALA NA ANG TUNOG DAHIL MAINIT NA ANG MAKINA PAG DATING DUON.HEHE.. HINIGPITAN LANG ANG BELT AYUN SOLVE NA PROBLEM.
Yung extra AUX Fan is useful sa mga naka montero. Mag improve daw yung AC system since may extra...
