Page 2 of 2 FirstFirst 12
Results 21 to 25 of 25
    mga magkano kaya ang pa-change oil ng compressor? iba ba iyong thermostat control diode sa thermostat (kaka-replace ko lang nito kasi)
    Jul 2005
    #22
    Quote Originally Posted by Potter View Post
    i have a similar problem sa aircon ng tsikot ko, i have a toyota corolla xe 97, pag switch ko yung aircon only the blower in the dashboard ang aandar and it will take several minutes before mag on yung compresor and the whole system, pero minsan pag switch ko nag on naman immediately. Ano kaya problem ng aircon system ng kontse ko. Could pls anybody help me.
    maraming salamat.
    i have a corolla gli '93 model and i'm also having a similar problem. before i bring the car to a shop, is there some DIY checkups i can do?
    in my case, the aircon usually works but there are occasions when i switch the thermostat, nothing happens. blower is fine. i'm guessing this is probably electrical and some switch or wire somewhere is loose. hope somebody can give ideas where to look, thanks!
    Dec 2007
    #23
    Can anyone give me advice, my A/C just wont work, umanadar naman ung clutch ng compressor, tapos ung tube papunta s loob ng car may condensation and mlamig sya pero ung loob ng car hot air lng ang binubuga ng fans
    Dec 2003
    #24
    barado siguro ac line mo, wag mo muna paandarin, baka mag high pressure at masira pa components nyan...have it cleaned, probably replace drier, and expansion valve if necessary
    #25
    Quote Originally Posted by zildjian View Post
    ako din mukhang may problem a/c ko after cleaning. paminsan minsan specially kapag tanghali ay tutunog ng ehhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh the first time na i on the a/c pero mawawala siya kapag on off ko yung a/c for a few seconds. after that wala na dahil parang nakawarmup na siya. ang masama kapag balik ko sa nag-cleaning ay di na magpapakita ulit yung problema dahil nga nakawarm-up na. they suggested na na overcharged sa freon and that's what i'm thinking too so bawas ng unti. mga 1 month ay nawala yung symptom then suddenly ito na naman siya. the thing is hindi madiagnose maigi kasi kapag dating sa aircon shop ay normal na ang a/c ulit. ano kaya problema, i'm thinking na baka kulang or wala langis na nakarga. baka matulungan nyo ako. ty
    BAKA ANG AIRCON BELT SIR MALUWAG. YUNG SA AKIN DATI PAG MALAMIG PA ANG TEMP NG MAKINA MERONG SCREECHING SOUND NA NAKAKARINDI TALAGA PAG-ON MO NG AIRCON. PAG TANGHALI MO GAGAMITIN DI SYA UMIIYAK. USUALLY SA GABI LALO NA PAG MALAMIG PA ANG MAKINA TAPOS ON MO AIRCON DUN SYA UMIIYAK.DI MO RIN PWEDENG IPARINIG SA SHOP KASI WALA NA ANG TUNOG DAHIL MAINIT NA ANG MAKINA PAG DATING DUON.HEHE.. HINIGPITAN LANG ANG BELT AYUN SOLVE NA PROBLEM.
Anybody experience this on their A/C system
