Results 1 to 10 of 10
- Dec 2008
- 5
December 30th, 2008 05:33 AM #1good day tsikot bros! i drive a van, a hyundai grace (square lights). i already had my compressor replaced w/ a sanden. nun una ok sya. but lately, i noticed, nawawala yun lamig nya. i can still hear the compressor running though and i had it checked, ok naman freon level nya. whats weird is when driving, pagnawala yun lamig, di talaga sya bumabalik. but whenever i use the van from cold start, sobrang lamig naman ng A/C nya.tapos later on wala nanaman. hangin nalang lumalabas. what do you think is the cause of this problem? nanghihinayang na kasi ako dahil malakilaki narin nagagastos ko sa ac nya pero till now di parin nabalik sa good working condition talaga.
- Nov 2008
- 148
December 30th, 2008 07:07 AM #2Pina-check mo rin na ba evaporator at condenser?
December 30th, 2008 07:08 AM #3
high pressure, sobrang init na condensers mo, have your aux fans and pipes checked
December 30th, 2008 11:15 AM #4
sir sabi mo nagpalit ka ng compresor nagpalit ka din ba ng DRYER? EXPANSION BULB SA likod at harap minsan yan ang cause nyan nagbabara? lumalabas ang ganyan sira pag nag palit ng compresor ilang week or months lalabas ang ganyan sira
same with my kia pregio...
- Dec 2008
- 5
December 30th, 2008 09:35 PM #5yes sir nagpalit rin po ako dryer kasabay nun compressor.yun expansion valves ok pa naman daw sabi nun gumagawa sakin eh.pag naka high yun ac ko tsaka lumalabas yun ganitong problem.pag nasa 2 lang sya medyo ok naman.tsaka pag naka 4 yun ac parang ndi nag automatic,kapapalit ko lang din ng thermostat.siguro nga may bara sya somewhere. any recomended shop sirs? taga pasig po kasi ako kaya medyo malayo kela mang mario eh.
December 31st, 2008 10:27 AM #6
kung pasig ka taga taguig lang ako,pero di ko maipapangako sayo yung mekanik ko,kung alam mo yung ususan taguig tapat ng seaoil
December 31st, 2008 12:09 PM #7
browse ka sa mga recommended shops thread, baka meron kang makita
http://tsikot.yehey.com/forums/showthread.php?t=756
January 1st, 2009 01:48 PM #8
sir, if ok lang s iyo punta po kayo sa EMPIRE COOL CAR AIRCON REPAIR located at 2252 PASONG TAMO, MAKATI CITY. KOL AT 8924394 look for RONALD. free check up naman po.
January 1st, 2009 02:46 PM #9
mukhang nabiktima rin ang TS tulad ng marami. dapat lang ibalik mo dun sa gumawa, hangga't maari pa solve mo sa kanila yan. dapat sinabay na expansion valves niyan iniwan pa
ngayon mangangapa na naman natural pag nagbukas magpapabayad pa rin ng oil and freon yan. dami kaya laman niyan since 2 evaporator.
good luck
- Dec 2008
- 5
January 6th, 2009 12:59 AM #10good day mga sir! at last ok narin po ac ng van ko. i had them mechanics double check everything and we found out that the front expansion valve was the culprit. pinakita sakin ng mekaniko na naiipon lahat sa higher yun freon. nun pinalitan,ok na sya. but theres another problem, yun thermostat, pag naka high yun ac ko,pag nag automatic, di na nya binabalik yun compressor, yun aux fan nalang nagana.pero pag naka med lang yun ac ok naman. sa electricals po kaya yun?
Yes, i do think so. Since it's based on the 4th-gen delica/space gear, which in turn shares some of...
Mitsubishi Philippines
