Results 1 to 20 of 20
    Before we had the radiator fan changed, the aircon has no problem. Nung ibalik na sa min, una hindi napansin. Napansin na lang na pag nasa traffic at idle umiinit ang buga ng aircon, pag umaandar na lalamig ulit. We already checked freon, next would be aircon cleaning. But I have doubts cleaning would help. Wala naman problems sa lakas ng hangin, nasa temp. And somehow I think its related to the radiator fan change.
    Any thoughts?
    Any thoughts?
    baka sa radiator/engine fan na ipinalit ang problema. what car ba bro? clutch fan ba? brand new fan or surplus?
    Fan not running? Check power supply and fan itself.
    Jan 2013
    Dalin mo kay Jay-Air sa may Mindanao Ave. Ayos yan.
    Fan is likely not running.
    Sent from my Mi A1 using Tapatalk
    When this happens to our older cars, the problem was usually connected to the auxiliary fan not running.
    When this happens, during idling or traffic standstill, the compressor doesnt get enough airflow to cool it down. But when you are moving, it gets that much needed airflow.
    It could be during the work on your radiator fan (if it immediatelt happened after work was done), they may have inadvertenly disconnected a connector for that or it just happened to fail at that time (cant really say for certain).
    May 2018
    Quote Originally Posted by 17Sphynx17 View Post
    Agree with this, but I think Sphynx is referring to the condenser , not the "compressor".
    Quote Originally Posted by SoleusBB View Post
    Whoops. haha! Thanks for that.
    Nov 2012
    Sa fan nga siguro kung nagloloko yan. Baka mag overheat pa nga kung di kayanin. Kung cleaning pwede din option pero how old is the car?
    Just had similar problem and nagpalit na ko ng compressor. My car is 6 years old
    Sent from my LDN-LX2 using Tapatalk
    Quote Originally Posted by benchman View Post
    2014 chev spin.
    Thanks
    Quote Originally Posted by kris_13 View Post
    Thanks for the recommendation
    Thanks
    Thanks.
    All of you guys seems to be pointing at the fan nga. I'll probably check the fan nga kung tumatakbo during idle. Then maybe send it to shop again.
    Thanks guys.
    Feb 2019
    condenser siguro.
    the compressor doesn't need significant airflow.
    Quote Originally Posted by rusty_ryan View Post
    Masyadong maaga magpalit ng compressor naman.
    Nov 2012
    Intermittent na din kasi ang lamig ng aircon ko kahit hindi traffic. Minsan blower na lang walang lamig.
    Nagpalit din ako ng aux fan kasi nagloloko na din. And nagdagdag din ng fan para sa condenser. Mag 1 month na din so far ok naman, ilang traffic na din at naibyahe na ng batangas.
    Feb 2019
    Before we had the radiator fan changed, the aircon has no problem. Nung ibalik na sa min, una h Audacity Find My iPhone Origin indi napansin. Napansin na lang na pag nasa traffic at idle umiinit ang buga ng aircon, pag umaandar na lalamig ulit. We already checked freon, next would be aircon cleaning. But I have doubts cleaning would help. Wala naman problems sa lakas ng hangin, nasa temp. And somehow I think its related to the radiator fan change.
    Any thoughts?
    Have the condenser cleaned as well. Happened to my 2010 city last year.
    Fan was working, replace cabin filter every year or when its dirty.
    Noticed that the A/C struggles to cool the cabin when on a standstill sunny day, but becomes ok when the car is moving.
    Brought the car to my trusted Car a/c specialist, his diagnosis was the condenser is blocked. They still dismantled the evaporator to verify and just as i thought it was still clean after 8 years. Goes to show that we must regularly change the cabin filter.
    They also dismantled the condenser which already turned black due to years of going thru dirt and dust on our roads, Flushed to old freon and compressor oil and of course replaced with new ones. Also cleaned my radiator while their at it.
    From that day up to now A/C is still cold. I rarely need to set the thermostat to more than half. Always have it on half. If i go more than half it gets very cold.
    our car was like that before.
    binawasan ng aircon boys nang isang washer sa compressor clutch.
    many years ago, our liftback also wouldn't cool in standstill noontime traffic.
    lingayan ng aircon guy ng aux fan.
    it cooled great, after that.
    Sep 2018
    Most likely the cause of the problem would be a faulty cooling fan. Its purpose is to keep the radiator and condenser for the air-conditioner to cool during when in idle. If it's not functioning properly, this will cause the radiator and condenser to get very hot. I recommend that you should visit your trusted car shop to have it repaired to avoid worsening as this could lead to car overheating. Hope this helps!
    Adding an extra fan wont really solve the problem. Plus its added load to your alternator.
    Most of the cars sold here are designed for our tropical climate.
    at kung tumatakbo man yun fan, pwede reverse yun polarity
Aircon temp is hot when idle, cold when moving
